Trying to catch up on the latest trends for tile backers. I’m installing 12′ ceramic floor tiles. starting with 3/4″ ply subfloor over 16 oc. and would normally use 1/2″cement board. But no wait GP now has lightweight Denshield. has anyone used this for floor installs?
dens shield
I only am familiar with dens sheild being a gypsum product. I believe it is paperless drywall. It uses fiberglass instad of paper. I do remember reading about a new cement board product that replaced a manufacturers old product line. Its lighter and cuts easier. Is that what you are thinking of? If I was tileing a floor, I would use cement board and the schlueter deitra system. It creates a break between the moving subfloor of the house, and your tiled floor. The result is no grout cracks. Aledgedly, meaning I havent tiled a floor since the stuff came to the markey several years ago. BUT, when I do tile a floor again, thats what I will use.
I have used densheild products for exterior sheathing and interior shaft walls on commercial sites. I have not seen a Densheild product for a tile backer. If they have one it is most likely for vertical application only. The densglass products I've been around would not be hard enough tor a floor underlayment for tile. I have seen alot of cement board and cement fiberboard as a floor underlayment for tile over wood framing.
