i have a question on tile flooring on a concreate slab floor. thinset set vs mud. floor is aprox 20’x20′ and as of yet have not checked flatness or level. thanks for any suggestions.
I don't understand your question.
Thinset is a "glue" for tile. No matter what your setting bed is, thinset will always be used to adhere the tile. So thinset is not an "either/or" alternative.
Mud is a setting bed, e.g., something that the tile is set on, e.g., the equivalent of backerboard, concrete, or drywall. Mud is the premier setting bed.
Care to re-phrase your question?
Regards,
Boris
"Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
thanks for your reply. the thin set i mean is something like " flex bond" ,sold at homedepot. the mud i refer to is the sand and cement mix generally used in showers and much thicker and can be used to level the floor and set tile in. i am not a tile setter and have been given this information by another contractor. my understanding was that if the floor was not too bad that i could thinset the tile to the floor. if not the floor could be leveled with mud and tiles set in that. i have a customer who is having thier kitchen gutted and asked about tile floor. i would like to give them as good information as i can concering level,flatness,dampness or anything that might affect the floor. tanks again for your comments.
There are few situations where any tile (ceramic, vct, etc.) applied directly to a floor slab has given an entirely satisfactory perfomance.
Not the tile's fault, nor the slab's; just a case of two different "things" wanting to do two different functions.
What floor was in the to-be-gutted kitchen?Occupational hazard of my occupation not being around (sorry Bubba)
floating wood,looks like Pergo
Flat and level are two different situations. You need to correct an out-of-flat floor if the differences are significant. Bumps and high spots need to be knocked down, and depressions need to be filled if they are more than about 1/8" deep. A floor can be flat but not level. Maybe you need to make the floor level, and maybe not. You could have a situastion where, if you make the floor in a room level, then it would create a step at the doorway to the adjacent room.
Thinset can be used to fill small depressions. Mud beds are usually at least an inch thick.
