Tile questions
upnorthframer | Posted in General Discussion on November 25, 2008 04:53am
I just finished installing schulter underlayment in my bathrooms/laundry rooms.  I used the specified thinset and now need unmodified thinset for setting the tiles.  I just wondering what size trowl to get for putting down 13″ x 13″ tiles?  I just saw a small article in my new FHB magazine, but it didn’t give specifics.  I’m currently using a 1/4″ x 1/4″ square and it seemed to work well for the underlayment.
Also,  I need to tile over the durock in my showers.  Could I use kerdi-band tape to seal the joints of this or is it best to use thinset and mesh tape?
upnorthframer
“If you think education is expensive, try ignorance!!!”
  1. MikeHennessy | Nov 25, 2008 04:59pm | #1
    1/4" notched trowel is what I'd use.
    Kerdi-band over durock wouldn't do much for you -- since the durock isn't a moisture barrier, no sense in making the seams a moisture barrier.
    If you haven't installed the durock, I like to use GP Denshield (which IS a moisture barrier) and Kerdi band for the seams. Otherwise, I'd just go with the mesh & thinset.
    Mike Hennessy
    Pittsburgh, PA
Mortar for Old Masonry
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
