Tile Saws
JoeyB | Posted in Tools for Home Building on October 6, 2004 02:46am
I’m looking to purchase a tile saw. Has anyone used the MK370exp?
Coming to you from beautiful Richmond, Va.
  1. Toolsguy | Oct 06, 2004 03:24pm | #1
    Yep, I have. Just bought one a few months ago. Works great. Some folks will tell you that the slide sticks a bit. True. Just push from the left and it works great. Also the plain 370 has a plastic slide that warps over time, the 370exp, however, has an aluminum slide so your'e good to go with that.
    Make sure you completely submerge the pump and it works fine. I initially didnt put enough water in the tray so it wasnt sucking up enough water. I called MK and they sent me a new pump just in case it was the pump.
    Other than that, it cuts great.
    1. Sancho | Oct 06, 2004 04:32pm | #2
      Dude I bought a length of the plastic tubing and drop the pump into a 5 gal bucket. That way you always will have clean (er) water running through the pump which will extend the life of it. just gotta drain the tub when its full. Oh yea I forgot. You might want to check out felker, though I hant used pone myself as I have a MK 770 I have heard nothing about good things about them
      Darkworksite4:
      El americano pasado hacia fuera ase la bandera
      Edited 10/6/2004 9:34 am ET by RonT
      1. Toolsguy | Oct 06, 2004 04:47pm | #3
        Thanks man. Yeah I heard some people do that. I hadn't tried it yet but its a good idea. Thanks.
        JeffBuck | Oct 06, 2004 11:52pm | #4
        Ya know ... sometimes you're pure genius!
        I've never thought of that ....
        gonna buy some tubing tomorrow!
        1. Sancho | Oct 07, 2004 06:28am | #7
          and If ya need to cut 45 degrees use a speed square with stair gages....
          thank ya thank ya very much..ill be here all night...(my best elvis impression) :>)
          Darkworksite4:
            JeffBuck | Oct 07, 2004 06:33am | #8
            well ... that one I knew ... w/o the nubs.
            might be bacause I lost the little fence that came with mine though .....
            necessity ... she's a mother!
          2. Sancho | Oct 07, 2004 05:38pm | #9
            they sell a kit with nothing but attachments. but as you can tell i improvised all the ones i need....necessity being the mother of invention and all...
            Darkworksite4:
          3. FastEddie1 | Oct 09, 2004 02:07am | #13
            Ron, why are the stair gages for?  I mean, I know why most people use them ...
            I use a plastic speed square in case I get too close to the blade.
            Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
          4. Sancho | Oct 09, 2004 03:13am | #14
            The stair gages are about the same thickness as the fence on a speed square. So when you attach the gages the speed square will lay flat/level on the TS table
            Darkworksite4:
          5. FastEddie1 | Oct 09, 2004 04:46am | #15
            Oh! Right!  I did have that problem ...
          6. sharpblade | Oct 09, 2004 06:32am | #16
            WRT sliding table sticking, a spray of some teflon based lube on the rails, and pushing he slide nearest to its support (left side  on my saw) works well for me.
    RichBeckman | Oct 07, 2004 02:19am | #5
    I have the MK 370. Although it hasn't gotten as much use as I would've liked, it has certainly performed in a satisfactory manner.
    I believe the instructions that come with the saw mention the advantage of putting the pump in a separate container of clean water.
    Rich Beckman
    Another day, another tool.
  3. FastEddie1 | Oct 07, 2004 04:55am | #6
    I have the regular 370.  The sliding table sux big time.  Mine is plastic ans has a definate sag, which causes tiles over 6" to snap near the end of the cut.  The exp model has a metal table, which should solve that problem.
    Other than that, it is a decent saw.  A bit loud, and the table is sensitive to being pushed from the right, but not a bad tool.
    I tried the longer water tube, but had two problems: the bucket empties, and the tray fills.  So now you have used water where you don't want it, and no clean water in the supply side.  The pump has a little mesh filter ... let it do it's job.  Change the water at lunch time and keep on going.
  4. ChrisV | Oct 08, 2004 09:19pm | #10
    Joey,
    Just purchased a MK101 a few weeks ago, used it to cut pavers , very happy with it!
    Chris
  5. EdJW | Oct 08, 2004 10:29pm | #11
    Joey,  Look at the Pearl tile saw, it's more expensive than the MK370 and MK101 but it's a much better saw.  I have the MK370, it's ok for small tile but if you plan on using it alot go with a 10 inch saw.  Here's a link that sells most all brands at really good prices.  Ed  http://constructioncomplete.com/TileEquipment/index.html
  6. sailr | Oct 09, 2004 12:41am | #12
    How much are you going to use the saw?  I normally buy top of the line everything, but when I when I was recently looking for a tile saw I ended up buying the 10" one from Harbor Frieght.  I only did so after checking a number of other tiling forums and the concensus was pretty consistent.  If you are only going to use it occassionally, the saw is perfectly fine.  It pays for itself after 2-3 days (vs. rentals).  Occassionally their stores mark them down to $199 from the inflated $399 price, but you can usually find it online for $199 w/free shipping.  I checked a number of places and a number of models, including on Ebay, and it ended up being the best value around.  I've used it several times and had no problems, even on 14" porcelain tiles.  Even if the motor goes bad, I can still replace it with a Baldor and be ahead of the game.
    However, don't skimp on the blade.  Buy the best you can afford.  Also, don't expect to get it quickly from Harbor Freight.  They ship via common carrier from California to a regional UPS hub.  Consequently, you have to wait for it to ship from their warehouse and then you have to wait for UPS to deliver it via Ground service.  I wasn't in a rush, so the couples weeks it took was worth the $2-300 I saved.  They are also notorious for back orders.
  7. ikor | Oct 09, 2004 02:02pm | #17
    Model depends on how much you will be using it, etc. but definitely look at Felkers saws...seriously good equipment.
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
