Why are tile saws mostly with the motor above the table? As a woodworker, I’d much rather have a tile saw that was like a table saw, with the blade under the table. This way, I could see the line and cut pretty much any angle. All the saws I see in the table saw configuration look like toys. Has anybody ever seen a table saw style tile saw in professinal grade?
So they can use cheaper drip proof motors vs TEFC's.
Cheaper to mfg the whole machine.....
Helps to keep the wet abrashive crud out of everything...
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....
WOW!!! What a Ride!
Felker Tile Magic.
while I've never used this saw ... been one I've thought about buying for some time now ... same reasons as yours. Mark a line and pretty much unlimited capacity too.
Buck Construction, llc Pittsburgh,PA
Artistry in Carpentry
Check this one out too... It's a little cheaper and I think I like it better.
I've got one of those little saws... I really like it. Easy to see what I'm doing for intricate cutting. Darn site more portable than the big one I used to rent. I was afraid it wouldn't have enough power. But I did a floor with 3/4 to 1 inch slate reclaimed from a bank. It did a good job. --- BRICK
"They say that there is a fine line between genius and insanity. I like to color outside the lines...and then eat the crayons." ~ Me
