I recently did a bathroom remodel on an investment property. The bathroom was gutted when I bought it. I put a subfloor down with a vinyl cover. My problem is that there must have been a tile floor prior, because the bottom of the flange sits 1/2″ proud of the floor. Now the toilet wont sit properly. The flange is soldered to 4″copper. Do I just cut the flange and put a new one on? Or do I take it off all the way to the stack and replace everything with PVC.
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
You could cut it off flush with the florr line & install an instaset¯ http://www.instantset.com/closet_rings.htm
Might require a double gasket as copper has a smaller OD than cast iron.
“The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
Look at these options.
http://www.plumbingsupply.com/toiletflanges.html
Go buy a 1/2" thick shhet of high density plastic, like a stiff kitchenm cutting board. lay hte potty on it, trace the outline, cut and sand, looks like it was meant to be there.
Melt the solder and push the flange down.
Resolder.
Go down in the crawl/basement cut the copper back a bit, put a Fernco on and run PVC back up to the toliet flange.
Take the copper to the scrap yard and save the $$ for beer.
Loosen the strap holding the drain line, lower the flange, reattach strap.
If all else fails, get a bigger hammer.
