Tricky plumbing problem…help!
mmoogie | Posted in Construction Techniques on May 14, 2008 12:07pm
I’ve got a bathroom drain-line problem with some work that my plumber roughed in and I can’t get him back to fix. I usually do my own plumbing, but don’t know how to fix this problem.
The toilet flange wound up having to move 1 1/8″ forward after a change in plans for finish wall surfaces. Now it misaligns by 1 1/8″ with the 90 degree bend that it is supposed to drop into. The hub-to-hub distance is only 5 1/2″ so I’ve got to find a way to offset 3″ PVC by 1 1/8″ in just 5 1/2″. The offset toilet flanges are too offset, and the 90 degree bend that it must mate to is not moveable without re-doing a whole lot of the rest of the drain work that shoots off on 45 degree angles. Is there some kind of flexible fitting that could work in a hub-to-hub situation? Could I heat a piece of PVC and deform it to the offset?
This is all in a crawl space with about 12″ of room. I thinks that’s why I can’t get the plumber back.
Steve
  1. Sungod | May 14, 2008 12:46am | #1
    Are you saying that the toilet is too close to the back wall?
    I have seen a homeowner cut a hole in the drywall and notched the stud so the tank is recessed into the wall. He finished it off so cleanly, that it was only noticeable when the tank lid was taken off.
      mmoogie | May 14, 2008 02:57am | #4
      The flange is in place in the floor at a 12" RO. The toilet is on site. The wall is finished with custom wainscot. plus a piece of hot water baseboard has to sneak behind the toilet. So I'm locked in to the current flange and toilet placement. I can cut all the drainage apart and re-do it, which may be what I decide to do in the long run anyway because of other reasons, but if there is a quick fix that will let me hook it up now with minimal disruption, that will score me some points and save the HO some money.Steve
        Sphere | May 14, 2008 03:27am | #5
        If you were a total hack, you could find some 4" dust collection type hose with smoothe wall inside, and some radiator hose clamps.
        Of find a truck air filter cowl duct..I mean BIG truck.Spheramid Enterprises Architectural Woodworks
  2. jej | May 14, 2008 02:25am | #2
    could you get a toilet flang with a 45 molded hub then use maybe a couple of 22 streets to do the off set
  3. rondon | May 14, 2008 02:34am | #3
    what about using a 10" RO.  That would give you 2 inches more than a 12"
    Dinosaur | May 14, 2008 03:56am | #6
    Use Lead.
    That's the only legal material I know of which might be flexible enough to deviate 1-1/8" in 5½".
    Get a 10" long toilet lead with a 3" ABS collar bonded to it and glue that into the 90. Then gently and patiently bend the lead until it comes up where you need the flange to be. Use a flat brass flange ring instead of an ABS hubbed flange fitting. Cut off the excess lead pipe and fair the edges down over the flange ring as shown here: http://forums.taunton.com/tp-breaktime/messages?msg=103509.11
    You might need to pre-bend the pipe before installing it if the subfloor's already down and working space is tight.
    Be careful not to flatten the pipe too much when you're bending it or that toilet won't flush worth a shït.
    Dinosaur
    foolish men call Justice....
      mmoogie | May 14, 2008 05:10am | #7
      Thanks Dino. That looks like just the ticket. Hope my supply house carries them...Steve
      mmoogie | May 14, 2008 05:16am | #8
      I'm gonna hijack my own thread...Anyone know of any software that will do a 3D layout of DWV lines? It's darn hard to sketch those oblique drawings of drain layouts.Steve
        Dinosaur | May 15, 2008 01:31am | #9
        Autodesk's ACAD will do it...if you can drive the software at that level.
        I can't; but CapnMac can do it with his eyes shut.
        Dinosaur
  5. rnsykes | May 15, 2008 03:35am | #10
    one of these?
      mmoogie | May 15, 2008 04:59am | #11
      Too much offset. That's the problem. I see no stock solution with a 1" offset.Steve
      Edited 5/14/2008 9:59 pm by mmoogie
        coonass | May 15, 2008 06:14am | #12
        Steve,Can you move the toilet over a little so the offset flange swivels to get your 1 1/8? Shouldn't have to move much.KK
      2. plumbbill | May 15, 2008 07:01am | #13
        Sure they do.
        http://www.plumbingsupply.com/toiletflanges.html
        Torque set 1" offset closet flange
        Heavy duty torque set offset cast iron closet flange with compression seal to waste line
        Ideal for new or retrofit installations
        Description
        Price & Quantity
        4" Compression
        $42.81
        You have 3"------ no problem
        Glue a 4x3 bushing over the nipple comming out of the 90.
        - Or -
        “The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
        1. BoJangles | May 15, 2008 03:02pm | #14
          I continue to learn something every day!!  You did it again ;
          mmoogie | May 15, 2008 03:34pm | #15
          Thanks Bill!Steve
          mmoogie | May 16, 2008 03:56pm | #16
          Well, of course my local plumbing supply houses had neither of the workable options (the lead or the 1" offset) So I wound up cutting it all apart and re-routing anyway, which I had other valid reasons to do...Steve
Solar Shingles in Austin
A Tesla roof powers this five-bedroom Texas home and then transfers extra energy to the power grid.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
