In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Tricky retaining wall
Quickstep | Posted in General Discussion on November 5, 2002 04:07am
I need (want) to build a retaining wall to expand my yard a little bit and to protect from erosion. Here’s the tricky part. The hill is fairly steep, 45 degrees. It also has big variations over the course of where the wall will go, making establishing a level starting point very, very difficult. The soil is very soft and sandy. To top it all off, the topology and steep slope make getting equipment to the site a veritable impossibility. Oh yeah, one more thing. I’d iek to make the wall a semi-circle. At it’s highest point the wall will be about 4′ in the middle and drop to 2′ toward the ends. The length of the semi-circle will be about 60′ overall.  Any ideas?
  1. Piffin | Nov 05, 2002 04:16am | #1
    Ideas?
    Money will solve all your problems
    - with the wall anyway
    "The first rule is to keep an untroubled spirit. The second is to look things in the face and know them for what they are." --Marcus Aurelius
  2. JohnSprung | Nov 05, 2002 04:24am | #2
    First of all, discuss it with your neighbors.  Retaining wall work has the potential to affect their property, and they're less likely to be on your side if that happens as a surprise.  Likewise, they may want to do something that would affect you, and doing it as a joint project could be advantageous to both.
    -- J.S.
  3. Frankie | Nov 05, 2002 07:50am | #3
    Not enough info. How far will this wall extend? Will the ground be level/ almost? Is the difficulty of estblishing a level wall line because of the uneven footing terrain or the terrain from where the extension begins? Why is the wall height tappering? Upper or lower terrain motivated?
    Sounds to me like the success will be determined by how much you fight or embrace what you have. The terrain slopes - Great! That means all the heavy stuff you need to carry down to the site will roll themselves. Only the empty mortar bags and off cuts of lumber will have to be carried up.
    Do a search on what type of tie backs/ anchors you want/ are appropriate to use. Concider using an undulating curve (Kudos to Thomas Jefferson) for the wall. Lots more structural stability.
    bobl | Nov 05, 2002 04:44pm | #4
    4 ft max height?
    look at the modular concrete blocks, can't remember names, usually locally produced. they interlock, no morter
    if memory serves, (CRS), can go 4 ft high w/o emgineering.
    footing is "easy".
    there are many sizes, need to pick the right one.
    http://www.pavestone.com/commercial/walls.html
    bobl          Volo Non Voleo      Joe's cheat sheet
    Edited 11/5/2002 8:47:28 AM ET by bobl
    Edited 11/5/2002 8:51:50 AM ET by bobl
      CloudHidden | Nov 05, 2002 05:43pm | #5
      Agree that this should be on your list to research. I've used Mesa blocks. It was carried by a local material supplier, not a box store, though the box's have their own brand. They have ways of connecting to the earth being retained, of shedding water, and of taking curves. And though the blocks can be heavy--mine were 75#; others are half that--you can at least carry them by hand if you have to.
    Brian_Pontolilo | Nov 05, 2002 06:19pm | #6
    What type of material were you thinking of using?
    I prefer natural stone, but there are a lot of nice materials out there that are good looking, durable and easy for less experienced wall builders to use, including timber, which is a pretty simple material for retaining walls. (well, maybe not if it curves)
    Here is an idea:
     When you excavate for the wall, you are going to have a lot of left over material.  Why not increase the height of the wall, throw the extra soils up above, and mellow out that steep grade.  Maybe you could add come compost (or better material than the sand that is there now anyway) and turn the otherwise unusable area into a garden of some sort.
    It sounds like a fun project.
    Good Luck.
    "I stand by all the mis-statements that I've made."
Cordless Random-Orbit Sanders
The new 18v GEX18V-5 and 12v GEX12V-5 finish sanders from Bosch provide ergonomic palm grips, easily accessible speed-selector dials, and side-mounted dust bags.
  • Cordless Drywall Cut-Out Saw
  • Podcast 461: Adding a Screened Porch, Insulating a Raised Addition, and Preventing Termites in Exterior Foam
  • Decompartmentalizing a 1940s San Francisco Home
  • Upgrade Your Window Air Conditioner
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Tool Guide 2022
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
