Trim for shower pan?
PaulBinCT | Posted in General Discussion on February 21, 2008 04:34am
We’re coming down the home stretch of the bathroom from H*ll and there’s a detail that has me a bit stumped.  We had to install the shower pan on a secondary piece of plywood in order to level it (long story but that’s the upshot).  Now I’m trying to come up with a trim material that I can run around the bottom edge of the pan to conceal the secondary “base”.  It’s complicated by the fact that the pan (a neoangle) has radiused (I’d say 1.5″) corners so I need to be able to conform the trim to this… any ideas?
PaulB
  1. seajai | Feb 21, 2008 04:58pm | #1
    Had the same issue last summer. I used a  1/4" thick corian threshold set on its side and siliconed in place. Once in place, it looked like it was part of the shower base. However, I have never tried to bend corian, it may be something to experiment with.
      PaulBinCT | Feb 21, 2008 05:13pm | #2
      Huh... interesting idea.  I remember seeing info about bending Corian, I think with some kind of heating blanket.  Worth chewing on... thanks!PaulB
  2. tmaxxx | Feb 21, 2008 05:24pm | #3
    typicaly when i install a shower base i like to trim the base to floor.  if the floor is wood then i use that type of wood.   if it is tile or lino i use white trim to make it look like part of the base.  use a real wood shoe mold or something that will fit your space.  as for the radius corners, i use bondo (yes the car stuff) to fill the little radius gap.  it dosent care about water and hardens in minutes wont shrink and sands easy.  then i prime and paint it with a oil semi gloss white.  then a little white caulk after all is dry.  looks like its part of the base and last long time.   you may not be able to nail the trim depending on the flooring.  use a good silicone or construction adhesive to hold it down.  you may need to put weight on it to keep it tight.
    i checked and i dont have any clear pics of that detail.  ihave even used alrge trim on bases before.  i dont like the plain flat fronts on bases.
    good luck
    Tmaxxx
    Urban Workshop Ltd
    Vancouver B.C.
    cheers.  Ill buy.
    JeffBuck | Feb 21, 2008 07:37pm | #4
    Azek?
    composite deck boards?
    do the layout on a sheet of ply ... lay the materials out .... mitered.
    then drill out that rounded inside corner with a hole saw
    sand the outside of same corner ...
    dress the top edge with a router.
    something like that.
    ie ... take a hunk of plastic and make it fit nice.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
      PaulBinCT | Feb 21, 2008 08:38pm | #5
      Thanks guys... as usual good ideas all!PaulB
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
