trouble with can lights
HPbuilders | Posted in General Discussion on January 27, 2005 04:33am
I am remodeling my kitchen and installed about eleven 60 watt can lights.  the lights are wired in series with the exception of one or two areas where one or two cans branch off (like a tree)  . all the lights are on one circuit and there are two switches.  oddly, the lights are burning out frequently ( days to weeks).  I don’t know why. help.  my wife is threatening to pay a professional, which will injure my pride as well as my wallet.
thanks, chris
  1. bigman | Jan 27, 2005 05:08am | #1
    Buy better lamps at an electrical supply house or try 130 volt lamps, the filaments are heavier. We have had bad experiences in the past with cheap lamps from H.D.
    IMERC | Jan 27, 2005 05:09am | #2
    in series wired  or in line as in pararell wired as in blacks to black and whites to white...
    install 130volt ratedbulbs...
    proud member of the FOR/FOS club...
    WOW!!!   What a Ride!
    1. HPbuilders | Jan 27, 2005 05:24am | #5
      wired white to white, black to black.
      chris
        IMERC | Jan 27, 2005 05:27am | #6
        better bulbs and and check the wattage rating...
        WOW!!!   What a Ride!
        1. HPbuilders | Jan 27, 2005 05:34am | #8
          thanks for the help everyone.  i'll try the 130 volt bulbs.
          chris g.
            IMERC | Jan 27, 2005 05:36am | #9
            did you catch the post on the base contact tab???
            WOW!!!   What a Ride!
          2. billyg | Jan 27, 2005 06:26am | #13
            Are you using non-insulated rated cans up against the insulation?  If so, the thermal circuit may be tripping.
            Billy
  3. gordzco | Jan 27, 2005 05:18am | #3
    I'm not an electrician, but are you sure they are burning out?
    The reason I ask is there have been a few jobs I've worked on where individual potlights go out for about 20 minutes or so and then come back on.
    Something to do with an a safety switch inside of them to prevent overheating.
    Be Constructive
    Gord
    St.Margaret's Bay NS
      IMERC | Jan 27, 2005 05:21am | #4
      may be 50 watt rated lights...
      WOW!!!   What a Ride!
      1. gordzco | Jan 27, 2005 05:58am | #10
        What about those curly flourecents? I think I even saw flourecent floods.
         Be Constructive
        Gord
          IMERC | Jan 27, 2005 06:00am | #11
          they have them....
          now if they give the lumen output hp wants...
          WOW!!!   What a Ride!
          1. gordzco | Jan 27, 2005 06:23am | #12
            Forget it, I don't think tdhey work with a dimmer, DWs need dimmers
            and candlesBe Constructive
            Gord
  4. calvin | Jan 27, 2005 05:32am | #7
    If the proper lamps are in the can and the trims rating is ok, turn off the power to the lights and try prying down the contact in the socket.  On occasion arcing will occur with a poor contact between bulb and socket, thus shortening lamp life.
    Use an old beer can opener (pointed end) or an old style paint can opener (that usually has a bottle opener on the other end.  Hook the contact and pull down slightly.
    Quittin' Time
