What type of wire is required for the inside of a deattached garage/barn where the wire will be exposed?
I hope conduit is not required.
Dangerous electrical work and widespread misconceptions cause fires, deaths, and $1.5 billion in property damage annually.
I don't know, but conduit is not that bad to put in.
The wire must be protected from damage, generally from the floor to something like eight feet up, plus anywhere where stuff might be stacked against the wall. In an animal barn conduit cannot be used as a ground conductor (due to corrosion issues), but is still recommended to protect the wire. In most other situations I believe that metalic conduit can be used as the ground conductor.
I'm not sure if smirf tubing qualifies as protective in these situations, but regular EMT metal conduit does, and I'm pretty sure that rigid plastic conduit does too.
So you can generally use romex but run it through conduit where exposed. Be sure to use "bushings" (a box fitting without the box, eg) where cable enters steel conduit, to protect the romex insulation from abrasion.
I thought no Romex in conduit? Isn't this against NEC? Thanks
Nope.
Would bx wire be ok as well with out conduit? Thanks
"BX" covers several different cables/flex conduits. Depends.
MC style...
WOW!!! What a Ride!
conduit is better...
WOW!!! What a Ride!
We have a monthly flea market nearby, and I've found the flex metal conduit with No.12 copper inside. I think it used to be called "Armor Flex". I also found 20' lengths of just the hollow aluminum flex material to run my #6 wire from the breaker box to the wall mounted heater/air conditioner.
I'm running this type of wiring in an outside wooden shed I'm currently building. This way, the flea market purchases have made it more than economical, and with pests sure to try to find their way into the new shed, it's chew-proof.
Most of the Box Stores carry the flex wiring; it's just expensive, but a dream to install.
Bill
