under floor insulation
| Posted in Energy, Heating & Insulation on April 3, 2003 04:28am
Other than batted insulation that keeps falling from underneath the floor (held up by staples or insulation fasteners),  is there a better way to insulate the floor above a 5 foot high crawl space.  Is there a foam or DIY spray or what ???
Thanks, Ken
  1. CAGIV | Apr 03, 2003 05:45am | #1
    Ken do you already have the bats in place?
    If you do you could either run 1x2 every 4 feet so across the joists to keep it up, or use stiff wire to prop it in place every couple of feet between the joists,  The 1x2 may be more expensive but its a lot faster and the cost would be marginal.
    View ImageGo Jayhawks
  2. Bruce | Apr 03, 2003 06:16am | #2
    Others have posted a link here to a site where  you can rent big cansters full of 2-part spray insulation.  I thought I had the link, but can't find it.  Anyone out there know the one I'm talking about?  Could use it again myself; I think it's a good solution for insulating rim joist bays.
    Formerly BEMW at The High Desert Group LLC
A New Approach to Foundations
