Unexpected Use for A 2×2
renosteinke | Posted in Construction Techniques on October 9, 2014 04:21am
One of my least favorite things about using aportable saw is trying to figure out exactly how far to offset your guide from the actual  cut line. Somehow, the blade to base edge measurement never seems to be an exen number.
Next on the list is the challenge of supporting smaller pieces.
Well, today’s project suggested that the solution has been nearby all along.
I found that an ordinary 2×2 provided nearly the exact spacing I needed between the cut line and the saw guide. Any ‘error’ was within the very wide marker line I had drawn on the plywood. Mind you, I was using a Makita Hypoid saw, and I cannot saw whether other saws have the same clearance.
Next, I found that the clamps I used to hold my guide in place were a good match in thickness to the same 2×2. This means that I was able to use them to support a smaller piece atop my table to cut it.
I’ve added two pics to show this in use.
    coonass | Oct 09, 2014 06:36pm | #1
    Reno,
    If you screw that guide to a 8" rip of 1/4" plywood and then run your saw your saw down the guide you have a shoot board. Much cheaper than the EZ or Fest Tool guides and works almost the same.
    KK
  2. calvin | Oct 10, 2014 10:09am | #2
    Reno
    You'd also be advised to support your work across (perpendicular) to the cut.  With what you show in the first pic, the weight of the saw will pinch the blade at the end of the cut, not a good thing for the work or your digits.
