uplift pump anybody?
geilerzimmermann | Posted in Construction Techniques on December 12, 2006 12:29pm
Anybody out there ever install an uplift pump? The type you use when installing a bathroom below your main drain to lift up to the height of your main drain as in installing a bathroom in a basement. Any comments and opinions would be greatly appreciated.
thank you
mark
  1. IronHelix | Dec 12, 2006 03:07pm | #1
    Locally the call out is for a sewage ejector with a sealed sump.
    Check you local and state plumbing codes to meet compliance.
    Done several houses in the past with that setup as a spec which is done by a licensed plumber to meet local codes.
    Down side happens when the pump fails and the basement is flooded with sewerage! An alarm system is available as a spec item, buy it with the package.
    Could be a "DIY"er if your knowledge base, expertise and skills are at a high level and the local codes are non existent.
    ..............Iron Helix
Critical Details for Ductless Heat Pumps
Trouble-free performance begins with properly installed line sets that pass rigorous testing for leaks.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
