Using miratec trim with gorilla glue
badarse | Posted in Construction Techniques on May 13, 2006 02:05am
I’m using Miratec exterior trim for the first time. I want to picture frame the windows , pre building them on the ground with pocket screws and gorilla glue. I was also considering using gorilla glue at the outside corner trim as well . I really don’t want the trim to open up. Any comments.
  1. Shep | May 13, 2006 03:27am | #1
    I used MiraTec and Gorilla glue for a similar type job last year.
    I haven't been back to see it, but I'm pretty sure these customers would have called if there was a problem.
    Just remember to wipe one side of the joint with a wet rag or sponge, to activate the glue.
  2. e2canoe | May 13, 2006 05:03am | #2
    Not really the answer you wanted but...  I tried Miratec two summers ago for porch facia.  I considered polyu glue but was paranoid so I used 2 part epoxy.  I can tell you that today the joints are still together (Ottawa, Canada - hot summers & cold winters).
FHB Podcast Segment: Waterproofing Below-Grade Foundation Walls
Learn about the pros and cons of waterproofing vs. damp-proofing foundation walls.
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
