using thin set to tile cold unheated mudroom floor in northern new england
not being a tiler, i am wondering if it ok to use thinset on a cold slab in an enclosed unheated breezeway in northern new england?
thanks
thanks
The Van Mark Trim-A-Table TAT60 works with both right- and left-hand saws and does not require the saw to be attached to a special plate that slides in the rail guides.
yes that would be fine
i would use a modified thinset and lightly dampen the concrete with a wet sponge before tiling
mabey let it set up for two days before grouting if it is cool out there
good luck nicko
yes
Use Modified definitely, and read the label, then maintain the required temperature while it is curing. Probably 50°F
Once cured, no more to worry about
