ventless vs. direct vent fire place
user-111755 | Posted in General Discussion on August 16, 2006 03:58am
I would like some info or opinions on LP gas fire places.
I am installing 2 fire places in my home which I am currently building. Building code says you must have a vented fire place in the master bed room. The fire place in the living room can be vented or non vented. I have been getting different info from the fire place contractors. The guys that don’t sell vent free say the vent free are no good and cause various problems. The guys that sell the vent free say they are more efficient and not problematic. I would sure appreciate some opinions from someone who doesn’t have their hand in my wallet. If it makes a difference I’m located in central N.C.
    G80104 | Aug 16, 2006 04:15am | #1
    Gas or Lp, both will be great to look at! have 2 gas fireplaces in my house, (Colorado) with the price of natural gas, if I could do it over again I would use something different.
      There both nice to look at but, worthless as a heat source!
    RRooster | Aug 16, 2006 04:30am | #2
    I have a direct vent and a standard vent in my house: propane.
    Direct vent can run straight out the wall and with one pipe, introduces combustion makeup air for the heater and vents the warm flue gases outside.  The cooler makeup air is on the outside of the pipe so the pipe never gets hot inside your house and the flue gases are on the inside of the pipe, insulated by the cooler air.
    Our other unit runs a pipe up the chimney and out and gets make up air elsewhere.
    Direct vent is the better way to go.
    http://grungefm.com
  3. USAnigel | Aug 16, 2006 04:31am | #3
    Vented: most of the heat goes up the flue, this is because few people balance the "air" flow. Much less chance of getting poisoned with CO. (still get a monitor)
    Non-vented: all the heat (and fumes) stay in the room/s. Hence the higher efficient rating. Much greater chance of getting poisoned with CO.
    Most of Both fireplaces have safety controls built in to detect loss of Oxygen and CO detection.
    I have the vent free and love it. To me its no worse than the cooktop being on.
    Exchange of air is important for both units to work right.
Episode 1: Drywall Tools for the First Coat
Learn about mechanical and automatic tools such as the taper, the compound tube, and the banjo to make your drywall job better and easier.
  • Monitor Both Outdoor and Indoor Air Quality
  • What You Need to Know About Installing Steel Siding
  • Podcast 570: PRO TALK With Project Manager Jeremy Hess, Part 1
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
