its been very cold the last couple night. very cold
been sound a sleep then BLAM, woke up whats that? ten second later BLAM all night. sound like its coming overhead. I got a metal roof on plywood. all my eaves are sheetmetal. nothing fancy, nothing loose. Its been windy too.
go outside with flashlight in cold and wind, nothing.
during the day no noise. next night 2 am. BLAM, ten second, BLAM all night long.
Finally after four night I found the problem. In the master bedroom, bathroom. water is dripping from the fart fan into a empty metal trash can that happen to be in the way. The can hid the water and the drips was slow in time. I happen to go in there just as it went BLAM.
ok, water is condesning in the pvc vent pipe. but the vent pipe is insulated. Its just this one, not the other bathroom.
How do I stop this. It could just be the very low temp. mid 20’s
Edited 1/3/2008 9:00 pm by brownbagg
Is there any way to put some slope in the pipe so the moisture runs to the out side. You could put a towel in the trash can to quiet it down temporary.
move to the tropics...
If I move any farther south, I'm going get my feet wet.
move the trash can.
Put a trap in the PVC pipe.
Woods favorite carpenter
Leave the fan running longer to evacuate the moisture from the line.
warmyour climate up so it is not so old.
As I write this it is zero outside this morning
Just like Matt said. Put a trap in the line, and run a smaller line pitched to the outside from the trap.
The trap may work if the problem is not too severe. I have poured out a quart or two of water out of a sagging flex hose. I you have too much moisture and cold, you will slowly fill up the trap, effectively shutting of the fan.
I understand that. But put a line to drain the trap at the lowest level so the water doesn't stay.
Wow, either you are a light sleeper or that garbage can has some seriously strong acoustical properties! haha.
Seriously though, if it is possible to insulate the ductwork that is the best bet - but you probably already ruled that option out for one reason or another.
Justin Fink - FHB Editorial
"Everybody wants to know what I’m on...
What I'm on? I’m on my bike, busting my ### 6 hours a day…
...What are you on?"
- Lance Armstrong
check for air moving through this fan.
They have a dampener which is designed to stop back drafts. But if it fixed open then it might be allowing air to continously flow out that vent.
The other thing is that you are not running the fan enough to clear the moist air and dry out the duct.
there is no such thing as a stupid question.
only stupid questioners.
"only stupid questioners."Actually, around here there are more likely to be stupid answerers.:)
Rich Beckman
This signature line intentionally left blank
oooo- stop, my 'ead 'urts.
hey, Im the king of stupid
And I am one of your subjects.
Rich Beckman
look down...
what you see is actually petrie dish medium...
I'd not put a P trap in line ...
that'd make for a pool of still water growing all sorta weird stuff.
plus ... with all the bugs in that part of the world ... might start a malaria farm in the attic.
I like the idea of running the fan longer ... maybe try one of the time delay shut off switches ...
but my first step would be to change the pitch so it drains to the exterior.
Buck Construction
Artistry In Carpentry
Pittsburgh Pa
Ya can't get malaria in Provo, Utah. <G>Spheramid Enterprises Architectural Woodworks
I looked at that sorta funny and then realized it was BB so had to check his personal info. I see Johnny has moved again!
Ya think he's practicing Mormonism?
Edited 1/4/2008 8:01 pm ET by DougU
Dunno. After moving from San Fran. who knows what he's into.Spheramid Enterprises Architectural Woodworks
HHHHHHHHHHHHHHHHHHHEEEEEEEEEEEYYYYYYYYYYYYY, I HAVE NEVER BEEN TO SAN FRAN.
At least he doesn't have to have his birthday on the same day every year.
good.
I wouldn't want him to get the Dengue ...
'cause then he might start acting weird.
Jeff Buck Construction
Pittsburgh Pa
What a stupid question !
A man, convinced against his will... Is of his own opinion, still. ~Anne McCaffrey
