In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Vix bits …help?
| Posted in General Discussion on January 8, 2002 05:01am
Hi,
I bought a couple vix bits made by hempe, a number 5 and a number 9.
My question is, are vix bits supposed to pre drill the hole completely?
The reason I ask is that the springs in these bits are so strong I can hardly press them down and when I do only about an eighth of an inch of the bit protrudes. Do I just not have them adjusted right, or what?
Any advice would be appreciated.
C
  1. Phill_Giles | Jan 07, 2002 11:56pm | #1
    C, the sleeve should move back into the body roughly 3/4 in the common models. The spring is generally very tough and many people could not push the sleeve that far with their fingers. If the bit is high in the sleeve and the sleeve is bottoming at 1/4 travel, then you can adjust the bit position by loosening the grub screw and letting the bit slide down until the point is even with the bottom of the sleeve. If it looks right but just won't move, then it's most likely chips caught in the mechanism and a little clean-up will fix it.
    I wouldn't mess with the spring unless it really is a necessity: you can anneal the spring with a lighter.
    1. ken_hill | Jan 08, 2002 04:47am | #2
      *Are those vix bits sized actually for #5 and #9 screws? I have some boxes of those altho obviously they are odd sizes. I've run into some situations with older 4" butt hinges where it seemed that the only screws that fit correctly were the #9 - #8 was too small for the countersink recess in the leaf and #10 stood proud. Am I correct about this application of #9 wood screws?
      1. C._Webb | Jan 08, 2002 05:01am | #3
        *Ken, I am not sure I can check. I have'nt used them much. I was reminded of my question and thought I would post it on here. I need to check them out more thoroughly.
  2. C._Webb | Jan 08, 2002 05:01am | #4
    Hi,
    C
How to Frame an I-Joist Roof
Engineered rafters are lighter, straighter, and often have more room for insulation than dimensional lumber.
  • Decompartmentalizing a 1940s San Francisco Home
  • Podcast 460: PRO TALK With Builder Keith Bohling
  • How to Frame an I-Joist Roof
  • Designer Kitchen Cabinets on a Budget
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Tool Guide 2022
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
