FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Wall Cabinet Knob Placement
geoman | Posted in Construction Techniques on June 20, 2009 10:55am
I hope this question isn’t too silly.   The doors of the wall cabinets that I bought from Home Depot do not have a mark or stamp that indicates where on the door panel edge one is to attached pull hardware.  Is there a rule of thumb as to placement of a pull knob?  These wall cabinest are 36″ x 36″ by 12″.    There are three shelves inside.  the base,  1/3 of the way up and 2/3 of the way up.    The knobs are a simple brass, circular knob.    If I had to guess,  I would install the knobs about six inches from the bottom corner.
    PaulBinCT | Jun 20, 2009 11:19pm | #1
    It's 99% personal esthetics... I'd say I usually go about 4" so 6 sounds fine if that looks better to you.
    PaulB
    http://www.makeabettertomorrow.com
    http://www.finecontracting.com
    Joe | Jun 20, 2009 11:30pm | #2
    Most times (for knobs)it's the center of the knob aligned with the center of the style and the top edge of of the bottom rail. But the absolute truth is you can put them anyway you or your customer likes ;-)
    http://www.josephfusco.org
    http://www.constructionforumsonline.com
  3. JTC1 | Jun 21, 2009 12:52am | #3
    I second joe's placement rule of thumb - that is where mine are placed.
    Working, I put them wherever the customer wants them and have placed as high as the middle of the stile, didn't look too bad with 30" cabinets.........
    Jim
      PaulBinCT | Jun 21, 2009 12:57am | #4
      For rail and stile doors, that's usually fine (if that's what he has)... the only problem I've found is that with less than great doors and stronger latches putting the knob that far down can really give you an annoying feeling of racking the door when you in effect pull on the extreme corner.
       PaulB
      1. Snort | Jun 21, 2009 01:26am | #5
        I like 'em like this <p><a href="http://www.flickr.com/photos/39626350@N07/3644474935/" title="DSC06530 by BucksnortBilly, on Flickr"><img src="http://farm3.static.flickr.com/2436/3644474935_bef9603813_o.jpg&quot; width="480" height="640" alt="DSC06530" /></a><p> centered on the stile and rail... turn your monitor upside to se them as wall cabs<G>http://www.tvwsolar.com
        1. Snort | Jun 21, 2009 01:28am | #6
          okay, like this, then
          View Imagehttp://www.tvwsolar.com
    Jeff_Clarke | Jun 21, 2009 04:47pm | #7
    As a rule of thumb for wall cabinets, they should be on the center of the vertical stile at the intersection of a 45 degree line from the closest panel detail (like glass or wood panel) - here are mine:
    6" is  a bit too high IMO.
  5. JeffinPA | Jun 21, 2009 06:35pm | #8
    Look at other peoples cabinets and decide what you like best but like Joe, we usually align with the top of the bottom stile or slightly up or down from that.
    There are probably geographic preferences like many other things because if you see something all the time, it tends to look right to you.
Practical and Sustainable Prefab Home
Two boxes make up the plan for this modular house: One has the kitchen and common area, while the other includes two bedrooms and two baths.
  • Convert a Porch to a Mudroom
  • Podcast 599: Trees Moving Buildings, Epic Thermal Bypasses, and Supplemental Dehumidification
  • Podcast 599: Members-only Aftershow — Tools That Changed Residential Construction
  • Remodeling Done Right
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
