Electrical mystifies,, I need some advice on wiring two 1500 watt 120VAC wall heaters to a programmable thermostat. The only line volatage unit I can find is rated to only 2400 watts. Should I install a transformer to step down to common 16 volt or is it 24 volt system. A higher rated unit? Pull out the 120VAC units and put in 240 VAC ones? Any electricians out there?
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
Based on the way you framed your question and your admission that "electricity mystifies me," I would really advise you to hire an electrician. I mean this not as an insult, but, while electical work can be demystified with some study and practice, there are some dangers inherent in just diving into a project such as you describe if the existing wiring/ supply is inadequate and your knowledge is sketchy.
Good luck
You need a relay (contactor) and a transformer and an
electrician. The relay is not a home center item, you
have to go to a distributor. You should have a separate
breaker for this setup.
