Hey folks,
Through my selfish need to have remote controlled light dimmers, I’m now stuck with the need for a wall switchplate of unique configuration. Toggle, decora, decora, decora, toggle. I was going to resort to using those “create your own plates” with the segments that lock together but they don’t fit around the dimmers very well and to be honest, they don’t look that good.
I searched for quite some time on the net with no results and my local suppliers say what I need doesn’t exist.
Any thoughts?
Mike
I have seen Decora toggle combination plates but not in the configuration that you described.
Tom
The only suggestion I could give you would be to reconfigure into a decora,decora,decora,stacked toggle and use a decora style stacked toggle
Bing
Have ya got a good scroll saw? :-)
It just might be easier and faster to make what you need from a blank.
I think designbing had the right idea but I am not sure he made it clear. You need to switch out your dimmers to a decora type dimmer. At least the ones that fit in this gangbox.
Can you get a 5-wide blank plate and cut your own holes?
Instead of usine regular toggle switches on the ends, couldn't you get "rocker" switches that are the same size as the decora things?
Then you could get a plate sized for 5 decora things.
Opportunity is missed by most people because it is dressed in overalls and looks like work [Thomas Alva Edison]
