Warped vinyl slider
JLazaro317 | Posted in Construction Techniques on July 24, 2008 05:43am
Any way to unwarp a vinyl slider? I’ve got one that we installed last winter that the center stile on the outer fixed panel has warped inward and the center stile of the sliding panel has warped outward. Kinda makes it difficult to close the door.
I’d hate to replace the door if I don’t have to.
John
J.R. Lazaro Builders, Inc.
Indianapolis, In.
    IMERC | Jul 24, 2008 07:44am | #1
    you need to replace..
    any repairs will go right back to it's current shape....
    BTW... look to see if everything is plumb....
    WOW!!! What a Ride!
    1. JLazaro317 | Jul 24, 2008 11:51pm | #4
      Thanks for the replies. I know that it is an easy replacement, but I always think it is a shame to trash some perfectly "good" door panels for warpage. I didn't know if a shim placed between them for the weekend might do the trick. The warpage is slight. 4' level on the stiles can only barely slip a business card behind. And everything is plumb and level.
      I guess I'll be ordering some new panels under warranty.
      Thanks,John
      Indianapolis, In.
  2. ChicagoMike | Jul 24, 2008 01:42pm | #2
    This problem should be covered under the warranty.
    "It is what it is."
  3. Piffin | Jul 24, 2008 02:24pm | #3
    It only takes a few minutes of your time to lift them off the tracks and fit and adjust the new ones in. This new of a door should be on the manufacturer.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
