Was advised to put sleepers directly …
| Posted in General Discussion on November 9, 2000 10:24am
I am attempting to insulate what was previously a carport. The Slab is 6″ thick and stable. I am pouring a 9″ sill wall around the perimeter to keep water out and headroom is an issue. I was advised to lay 2″ extruded polystyrene (pink) on the slab then fasten 2×4 sleepers on top of this bolted through to the slab, then sub floor over that. Will the polystyrene ever compact? Should I insulate between the sleepers as well? Do I need to insulate the exposed 5″ of concrete perimeter above the floor? I am in a cold winter climate in southern BC, no permafrost.
Thanks for your opinions.
DK
  1. Don_(no_hair)_King | Nov 09, 2000 10:24pm | #1
    I am attempting to insulate what was previously a carport. The Slab is 6" thick and stable. I am pouring a 9" sill wall around the perimeter to keep water out and headroom is an issue. I was advised to lay 2" extruded polystyrene (pink) on the slab then fasten 2x4 sleepers on top of this bolted through to the slab, then sub floor over that. Will the polystyrene ever compact? Should I insulate between the sleepers as well? Do I need to insulate the exposed 5" of concrete perimeter above the floor? I am in a cold winter climate in southern BC, no permafrost.
    DK
A New Approach to Foundations
