FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Water Heaters.
| Posted in General Discussion on July 21, 1999 04:13am
We are due to replace our old water heater and i am looking for the best way to go. Has anyone made use of the whole house instant (tankless) heaters? What is the performance like? Ever run out of hot water? Any failers? We have five people in the house and normal use is showers in the morning, washing up at night, plus the normal stuff. I want the most hot water for the running costs. i know fuel is going to increase!
  1. JRC | Jul 20, 1999 03:53am | #1
    It depends on what fuel you're comfortable with.
    Gas is cheap, but it has dangerous failure modes: carbon monoxide in the house and explosions from leaks and ignition failure.
    Oil doesn't have the explosive failure mode of gas, but it does make a toxic mess if any leaks. AFAIK oil WHs are basically the same as oil furnaces - they need a blower to get the air turbulence high enough to get clean combustion.
    Electricity is probably the most expensive, but once it's installed (properly), IMO it's the safest, and the only maintenance is replacing the odd dead element.
    Unless you have natural gas available, I would forget about tankless heaters. The energy required to adequately heat moving water is enormous. A 25 kW heater would not be out of line here. By comparison, the average 40 imp gal heater runs 3 kW elements, and at most one is on at any given time.
  2. Guest_ | Jul 20, 1999 11:42am | #2
    Get a gas heater with sufficient capacity for your needs. Inexpensive, 1/3 the operating cost of electric and plenty safe. Carbon monoxide detectors are of course a good precaution.
    1. Guest_ | Jul 21, 1999 04:13am | #4
      *There's already a discussion on this topic a little further down in this forum. See heading:Tankless hot water heaters
  3. nigel_martin | Jul 21, 1999 04:13am | #3
Scenic Views in Austin
This house west of downtown Austin, Texas, has floor-to-ceiling glass with no window treatments but uses the topography as a privacy screen.
  • Podcast 609: Flashing a Metal Building, Energy Retrofits, and Siting a House
  • Podcast 609: Members-only Aftershow — Building Business With Timber HP President Matt O’Malia
  • Podcast 608: Roofs with Self-adhered Membranes, Heating and Cooling Loads, and Introducing People to Trade Work
  • Podcast 608: Members-only Aftershow—High-performance Building with Mainstream Methods and Materials
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Pretty Good House
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
