My 75 year old house has a concrete foundation and brick walls on top of that. In the two years we have been here there have been three or four episodes of water running on the floor from the west wall of the basement during a heavy rain. The basement right now is paneled with vinyl tiles on the floor. I keep the gutters in good working order and the house has two foot eves all around. There is a two foot wide sidewalk adjacent to the house on the west side that is in good condition and graded away from the house. So I’m assuming that the water is coming in the house when the ground outside becomes completely saturated and the water penetrates through weaknesses in the foundation.
A little water on the floor is no problem now, but eventually I will re-finish the basement with drywall and carpet. I would like to try to solve the water problem and then wait for a couple of good storms to assure myself it is solved before finishing it. So my plan is to strip all the paneling out to expose the foundation walls. Then run a hose on the ground in various spots adjacent to the wall to see if I can identify the leaks.
Are my assumptions and plans sound? What should I do when I identify a water entry point? Should I seal the foundation from the outside some how? I plan to remove the sidewalk anyway at some point and replace with landscaping so I wouldn’t be oppossed to a huge digging job.
I know you said the gutters are in good working order but how far away from the house are you channeling the water? 9 out of 10 times the problem is water from the roof making its way back to the hole in the ground where the foundation is.
Then make sure all the landscaping slopes away from the house.
think like a rain drop
Two downspouts go into the storm drain, a third drains under my deck 15' away from the house. One of the downspouts that goes into the storm drain is near the spot where the water comes in, the pipes underground are the old clay type. I supposse I could take the downspout off and look down there with a flashlight to see if the pipe is broken.
