Weird water heater prob
pinko | Posted in Energy, Heating & Insulation on February 4, 2008 04:23am
Did some work for a customer wherein I had to shut off the main water to the house for a while. House was on well water, no main shut-off; had to kick the pump breaker and de-pressurize tank and house to shut it all down.
After I turned everything back on, one of her elec water heaters ( a small 19gal for the kit only) was not producing hot water. I checked it out: had power (120V unit), reset button was not popped, had proper voltage across the element, but no heat. I then shut it down and checked the element w/ my ohmmeter and read very little resistance (micro-ohms). So I determined that the element had somehow shorted/burned up (did the tank siphon out when I drained the system and fry the element?). Odd things was, the breaker had not kicked and I still had normal voltage to the unit. In any case, my DMM said the element was bad, so I said I’d replace the element.
Next day, she calls and tells me the hot water is working again.
It’s now been a week and she reports the hot water is intermittent–has it in the morning, usually, but not at night. This is a SINGLE element 120v 19 gal water heater using a 1500w element.. Whirlpool, standard 4 yr-old unit from Lowes. How can it be intermittently giving heat (I checked it when it was ‘not-working’ and saw voltage from the t-stat to the element) and how can a bad element be ‘sometimes’ good? And how can my briefly shutting down her water have caused this problem?
Anyone have any ideas?
  1. joeh | Feb 04, 2008 05:38am | #1
    The tank bled down while you had the water off, element died.
    Now the ghost of the element is haunting you.
    You need a new element or an Exorcist.
    Joe H
    1. DanH | Feb 04, 2008 05:15pm | #6
      Yeah, a burned out element can sometimes heat the water through electrolysis.  But the amount of heat is relatively small, so recovery time is quite long.
      1. pinko | Feb 05, 2008 02:24am | #8
        Dan, that sounds like exactly what's going on...and would probably explain my reading of a few micro ohms across the element (I did disconnect it before I measured it). HO says it's taking about 1/2 a day to heat the water. BUT ELECTROLYSIS! So she's potentially got hydrogen and oxygen building up in her tank right now?? Have you actually experienced this before?
          BillHartmann | Feb 05, 2008 03:14am | #9
          I am speculation that the element burned in two and one end is randomally making contact with the sheath (ground).
        2. gstringe | Feb 05, 2008 03:14am | #10
          Micro ohms is essentially a short, which would make for very high current, tripped breaker and probably smoke. Or do you mean megohms? which equals almost no current and no heat.I would lay odds on a defective element.Nobody gets in to see the wizard...not nobody...not no how!
  2. USAnigel | Feb 04, 2008 07:31am | #2
    According to my calculations you should be reading 9.6 ohms across the element.
    1500watt/120volt=12.5amps                    power=amps x volts
    120volts/12.5amps= 9.6ohms                   volts = ohms x amps
    I would suspect the element has gone iffy or you have a weak connection somewhere.
    1. pinko | Feb 04, 2008 04:49pm | #4
      I figured the tank bled down which would have fried the element...(and I didn't even know about it---it's located in a concealed cab. space next to the stove). There's no shut-off to the tank or on anything at all in the house. 9.6 ohms is exactly what I read on the new element I bought for the tank. But why doesn't the bad element read infinite ohms if it's open/broken? By the way, ohms is a measurement of resistance, but higher ohms means LESS or MORE resistance? ...
      1. john7g | Feb 04, 2008 05:13pm | #5
        Higher Ohms= more resistance
        0 (zero) ohms = no resistance (sw closed)
        infinite ohms = open line (sw open).  DMM may say OL.
      2. USAnigel | Feb 05, 2008 01:35am | #7
        I would disconnect the element and re-measure to rule out a bad connection somewhere before trying to remove the old element.
  3. wallyo | Feb 04, 2008 09:49am | #3
    If the pump is lower then the water heater you siphoned out the water when you bled the pressure tank remember the cold water heater fill has a tube that reaches the bottom of the tank, works the same way you siphon out gas out of a car. You must of opened a valve in the house to bleed out the water.
    So the element is probably almost burnt out. If that turns out to be the case talk to her about a shut off at least on the cold line to the heater.
    Wallyo
    Edited 2/4/2008 1:50 am ET by wallyo
    IMERC | Feb 05, 2008 10:55pm | #11
    the wlemrnt is damaged or the thermostst is sticking...
    change both and be done with it...
    WOW!!! What a Ride!
    1. DanH | Feb 05, 2008 11:02pm | #12
      Do you know of a good internet source for wlemrnts?
        IMERC | Feb 05, 2008 11:05pm | #13
        did you say watermelons????
Drafting the 2027 IRC
  • The New Old Colonial
