I have a 2x8x16 pressure treated that I’m going to use for a deck ledger. It’s a little bit wet right now, but I was hoping to install it. Can I install it while it’s wet, or should I wait until it dries. I was planning on putting it up and not doing anything else for a bout a week.
A small and dated house lends its foundation to a stylish new home with more than twice the space.
If you are through bolting, as required her in NC, I'd make sure to drill the holes a good 1/16" oversize or bigger. That way when the board dries and shrinks it won't have as much tendency to 'split' around the hole. Eslewise I would say mount away. Anchor the sucker before it dries and twists, warps and curls on you.
Let's not confuse the issue with facts!
What he said.
We don't have time to let wood dry before going to work. Work with wet wood, just compensate for it.
Grunge on. http://grungefm.com
Just out of curiousity, why do you need a 2x8 for a ledger? 2x4 is usual; 2x6 is considered a luxury.
Dinosaur
foolish men call Justice....
I belieee he is attaching a ledger the same height as the joist to attach joist hangers onto. I suspect that you are thinking of a ledger strip that the joist would sit on, ususally a 2x2, in lieu of joist hangers.Let's not confuse the issue with facts!
Okay--but just because I feel like picking a nit this morning (LOL) that's not a ledger, it's a rim joist.
Correct me if I'm wrong (get ready to duck, Dino!!)....Dinosaur
That would be a ledger out here, and it would be soaking wet. I don't think I'd do a ledger strip detail for an exterior deck, for a couple of reasons.
A true ledger can be flashed as I described above because the joists sit on top of the flashing and wall-drip water drains under them and away.
BUT: if using a rim joist and joist hangers, how to flash the sucker?
Can't be done that way when the joist top is at the same level: the flashing will lead the water right in between the joists and the deck boards. But it has to be flashed somehow...or water will seep right down between the house wall and that rim joist and rot it out along with the mudsill or sole plate that it's lagged to.
If I wanted to do nothing else but re-build rotted-out decks, I could. Only about one carp in five in this area flashes that joint properly. Most of 'em just run a bead of caulk down the deck/house joint and call it good. (It's not.)Dinosaur
If the one in five is true in your woods, then it can't be far off in everyone else's.
Sounds like a good topic for the magazine with pictures and diagrams, etc.
That figure is just a grumpy guesstimate, based on how often I get the same kind of plaintive call from some poor HO who thought he was gonna fix a few rotten deck boards on the weekend and just kept finding more and deeper rot....
The problem around here is that it's 'cottage country', and pretty much everyone wants a deck of some sort. So a lot of decks are DIY-built by people who are okay with a hammer and saw but don't really understand what water can do to a wood structure that's not correctly designed and built.Dinosaur
