What do I use to get smooth exterior …
| Posted in General Discussion on June 14, 1999 03:06am
I have an existing standard stucco finish on a small home (3 coat, no paint). I would like to find a product that I could apply directly over the existing color coat to get a very smooth plaster like finish. Anyone have any ideas, or no how I might go about this?
Charles
  1. Guest_ | Jun 11, 1999 02:10pm | #1
    Charles,
    Could you possibly reword this. I'm having trouble trying to imagine what it is you want to do.
  2. charles_Anderson | Jun 12, 1999 02:49am | #2
    I do not particularly like the what I would consider the standard sand finish on stucco. What I want to do is trowel over my existing stucco sand finish, with something? to create a very smooth plaster (interior smooth trowel finish) or limestone looking finish. I want to know how I might go about doing this?
    Thanks Mark
    Charles
  3. Guest_ | Jun 12, 1999 04:20am | #3
    Is this painted at the moment or just a colour coat as in tinted render?
    How course a finish is it at the moment?
  4. charles_Anderson | Jun 12, 1999 05:12am | #4
    Mark,
    No it is not painted just the stucco color coat. I dont know the correct terminology, but I would say the individual bumps (grains) are about 1/4" in dia. so fairly coarse...
  5. Guest_ | Jun 13, 1999 02:13am | #5
    Charles,
    This is not a job for a DYI. Unless you have a reasonable amount of experience with rendering ( and I'm guessing you don't or you wouldn't be asking this ) you really need to call in the trades.
    Without seeing the job, it sounds like it needs a skim coat to bring up the finish you are after.
    First they will probably put on a "key coat" to help the next coat bond. Then depending on the coarseness of your current coat, will either go one or two coats to finish.Final finish will be with a steel float polish by the sound of what you want.
    1. Guest_ | Jun 14, 1999 03:06pm | #7
      *Pool plaster is mixed with marble dust instead of sand and is quite smooth. It could, I'm sure, be textured like interior plaster. This would not be a DIY project.
  6. charles_Anderson | Jun 14, 1999 03:06pm | #6
    Charles
Choosing a Paintbrush
  • The New Old Colonial
