What does course aggregate do?
Soultrain | Posted in General Discussion on April 30, 2006 10:47am
This is more of a theoretical question, I’d like to learn more about the nature of concrete.
Is the purpose of gravel in concrete for strength?  What would concrete consisting of only sand & cement be like (simply replacing the gravel volume with sand).  Generally I thought that increasing the ratio of cement to total aggregate (sand & stone) increased the strength as well.
  1. gb93433 | Apr 30, 2006 11:06pm | #1
    Having a gradation of aggregate will give the best concrete.
      Soultrain | Apr 30, 2006 11:50pm | #2
      yes, I understand that, but why?  What function does the aggregate serve in the concrete?  Is there anyone on here that works for a ready mix plant?
      1. gb93433 | May 01, 2006 12:02am | #3
        Strength, durability and surface hardness. Cement is very soft. Sand will not wear nearly as good as coarse aggregate. You will use much more cement in a sand and cement paste. Gradation reduces spaces between larger aggregate
        Gradation affects the strength of concrete
        Gradation helps to reduce shrinkage crackshttp://www.cement.org/ will give you every answer you need.
        Edited 4/30/2006 5:09 pm by gb93433
  2. gb93433 | May 01, 2006 12:11am | #4
    The powerpoint file is a short part of a lecture I give on concrete.
  3. ponytl | May 01, 2006 12:40am | #5
    I'm sure there are folks on here who know alot more about concrete than i ever will but  i think i have every book and web page about concrete maked or read... i do alot of concrete alot of molds stamps forms and just flat work... makes you feel like god... who else can make ROCK ? :)
    portland  sand & lime = mortar  the more lime  the lower psi   the less portland the lower the psi... the higher the portland to sand the higher psi  (type O N & S ect...)
    add rock and take away the lime... thats concrete  in theory you want every void filled so it takes different size rock to join & fit together ... if you just had sand(ie fine rock) & portland... no matter what your portand ratio it wouldn't be very strong...
    once your aggregate ratio is correct (fine sand & everything bigger) the amount of portland added increases the strength of the final product... the less water you use also makes it stronger... an almost dry hard to work mix will be much stronger than a wet liquid mix... if you need a liquid mix then you need to make up for it with more portland...
    all this is just general rules... there is air... ad mixtures... pressure, heat, ect ..that all can come into play...
    p
      Soultrain | May 01, 2006 05:27am | #6
      Thanks everyone.  That's what I was looking for.
