In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
What fasteners for cedar shingles?
ChrisB | Posted in General Discussion on June 4, 2005 11:58am
I’m going to install cedar shingles on some gable ends of a new house we are about to start. The shingles will be put over Tyvek wrapped !/2″ OSB or plywood sheathing. What kind of and how many fasteners per shingle do you folks recommend?
I have a PC NS100A Narrow Crown Stapler that I got as a mail in freebie when I purchased a finish nailer/ brad nailer/compressor last year. Would a couple of 1″ narrow crown staples per shingles do the job?
Thanks in advance.
Chris
  1. RayMoore2G | Jun 05, 2005 12:00am | #1
    Furring strips behind the shingles are recommended.
  2. davidmeiland | Jun 05, 2005 12:14am | #2
    I recommend medium crown stainless steel staples.... 7/16" x 1-1/2"
    Probably cheapest to get them from Manasquan or one of the other mail order fastener houses.
    The 1" narrow crown staples are good for attaching 1/4" backs to cabinets. They will be woefully inadequate for installing shingles IMO.
    edit: read the sidewall fastener info at cedarbureau.org
    Edited 6/4/2005 5:15 pm ET by davidmeiland
    1. ChrisB | Jun 05, 2005 03:28am | #3
      Many thanks for the website. I just downloaded the manual for wall installation, and will go from there.
      Chris
    Fonzie | Jun 05, 2005 11:59pm | #4
    ChrisB,
    Don't be insulted but did you notice that article in FHB about back- priming cedar so the "tea" created by moisture doesn't "eat" the Tyvek?
    That might be why the furring strips were mentioned in this thread.
    1. davidmeiland | Jun 06, 2005 01:18am | #5
      Correct about cedar/tyvek, and I think the Cedar Bureau info mentions that. The furring strips are for air space behind the siding. To do so behind shingles would require that they be horizontal, obviously, with some careful placement so that the fasteners will hit.
      1. alias | Jun 06, 2005 04:17am | #6
        there this stuff we've used more and more frequently , called home slicker ,somewhat like cedar breather for walls . 36"x 61' , not effected by u.v.. time will tell in a decade or so, but it's seems like a pretty optimistic system." He who makes a beast out of one's self, get's rid of the pain of being a man"
      2. ChrisB | Jun 06, 2005 04:48am | #7
        I searched the web site you linked  high and low for info on putting cedar shingles over Tyvek and could find nothing. No mention of furring strips either. The web site does recommend using 30lb felt underlayment but makes no mention of Tyvek.
        I'll be safe and use felt anywhere we put down shingles, but I gotta say that out here in westen Colorado everybody slaps them down right on the Tyvek. Doesn't make it right, but with our ulta low humidity, water 'twixt shingles and Tyvek seems to be a non- issue.
        Chris
        1. alias | Jun 06, 2005 05:02am | #8
          the tannins in the cedar that leech out from the shingles , will breakdown the tyvek down. back priming the shingles wil diffuse that problem. or stick to the 30# felt , i open up wall 85-90 years old that the stuff still intact, and has got the repellant properties..." He who makes a beast out of one's self, get's rid of the pain of being a man"
          Edited 6/5/2005 10:06 pm ET by the bear
          Taylor | Jun 06, 2005 04:13pm | #10
          I think the mention of "furring strips" is as part of a rain barrier, give some breathing room for moisture that gets behind the siding. On another thread I think someone mentioned that a couple of strips of 30# felt paper would be enough thickness (on top of an "air barrier," obviously). Or use that homeslicker stuff.
          1. ChrisB | Jun 06, 2005 09:40pm | #11
            I think I found the source of some confusion here. These shingles are NOT going on the roof, they are going on gable ends as  siding. Therefore no furring strips are required, just put down over 30lb felt.
            Thanks to all for the help.
            Chris
            Taylor | Jun 06, 2005 09:53pm | #12
            Now I'm confused. I thought furring strips were recommended for walls (rain barriers), not roofs.
          3. RayMoore2G | Jun 06, 2005 11:24pm | #13
            Furring strips are recommended behind any wood siding. The shingles require that these be horizontal which diminishes their effectiveness. They should still be used and if you can figure a way to get air behind them to the sides, that would be good. When water is held behind the shingle against the material behind it, the drying process is extended.
            You are fortunate to be in CO where drying will happen quickly.(usually) The fast drying potential will lead to curling shingles if the back side is much slower to dry. Curling shingles will be less of a problem for you if you furr the shingles off the substrate. I agree with using #30 felt instead of Tyvek.
          4. ChrisB | Jun 07, 2005 12:44am | #14
            Hi Ray,
            Not meaning to start an argument , but if you go to cedarbureau.org and click on Wall Manual on the left you will get 16 pages "how to". There is no mention of furring strips.
            Also, most houses around here, from ten million dollar trophy house in Aspen or Beaver Creek, on down to our modest digs, use cedar siding,with board and batten being the most prevalent application. I stick my nose into as many new construction projects as I can in order to get building ideas. I have never seen furring strips behind siding on any project. In fact, the siding it is almost universally put directly over Tyvek. I guess we can get away with that in an area that gets twenty inches of precipitation a year, and 95% of that is the white stuff that stays white all winter.
            Not to say that furring strips would not be a good idea in high rain and high humidity areas like the South East. I do remember an article in FHB not too long ago on a very high end  house in Massachusetts (I think) where they had to tear off all the three year old  siding and go through what I thought was a Herculean effort to provide continuous air flow behind the siding. I thought at the time  that that must have been an awfully shady and wet area.
            Chris
          5. davidmeiland | Jun 07, 2005 04:11am | #15
            Chris, if you're interested in rain screen details, google for a guy that's a structural failure analyst/building scientist at Portland State U and has published a lot of studies over the years about water problems with wooden buildings. He recommends rain screens behind practically all siding, including stucco, fiber cement, etc. It has less to do with the type of siding than with preventing damage to the sheathing and framing. Obviously it's a lot more important in Portland than in your climate.
            The man in question is a presenter at JLC Live. His name escapes me... anyone?
        Dinosaur | Jun 06, 2005 05:29am | #9
        The spacing on the skip sheathing has to be equal to the exposure on the shake or shingle. So for a 7½" exposure on an 18" shake, you nail the skip sheathing (or furring) on 7½" centers up the wall or roof.
        You're right about the staples; Cedar Bureau specs are two ½" crown staples per shake, penetration must be ¾" into the substrate. They're got to be stainless or hot-dipped galvanized. If you're hand nailing, they specify 6d hot-dipped galvanized Box nails. Standard roofing nails are too heavy and will split the shake.
        The Cedar Bureau has a website with a very comprehensive installation manual on line. http://www.cedarbureau.org/techinfo/roofmanual/roofmanualcontents.htm
        Dinosaur
        A day may come when the courage of men fails,when we forsake our friends and break all bonds of fellowship...
        But it is not this day.
Fine Homebuilding – Aug/Sept 2022, Issue #309
Featuring installing crown molding on cabinets; sturdy walls without wood sheathing; success with construction tape; and much more.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
