What glue to attach stair bullnose?
ironick88 | Posted in General Discussion on July 24, 2012 10:51am
Hi
I’m building an interior staircase. I’m using 3-1/4″ x  3/4″ t&g flooring as stair treads on triple stringers and 3/4″ plywood “fillers” on cleats between the stringers. Flooring is to be nailed conventionally through the tongues using flooring nailer and/or finish nailer. When I get to the nosing I plan to screw the 3″ t&g nosing from underneath, through the plywood, and use glue to reinforce the connection, clamping the tongue of the last flooring piece horizontally to the groove of the bullnose.
Do I just schmear PL on the tongue and groove and the underside of the bullnose,clamp the joint horizontally, then put in the screws from  underneath? Is there something unforseen here that I’m overlooking? Anybody else doing it this way? Is there something better than PL in this application? Seems like the PL would take up any irregularities and be just flexible enough.
Critique, please.
Nick
  1. Piffin | Jul 27, 2012 08:10pm | #1
    whale now....
    for this situ, I would use Gorillia glue and amke up each individual treead before placeng it, t&G piecs and edge
  • Fine Homebuilding's Author Guidelines
