What thinset for Ditra????
grandchat27 | Posted in Construction Techniques on January 17, 2008 07:17am
Hello,
I’m looking at installing Ditra directly over top my subfloor (it’s extremely similar to “Advantech”) which is 3/4″ tall.  I’m just putting regular 13 x 13 ceramic tile over top, and according to the Ditra website, you can do this no problem w/o an additional layer of subfloor (as long as it’s not stone, too big, etc).  I’m running into difficulty though where none of thinset I can find will warranty it if there is any issues b/c they don’t know how well the thinset will stick and hold to the engineered subfloor product (it’s a Weyerhauser product called “Edge Gold” – no one around here can get Advantech and from what I could tell this is extremely similar).  Would anyone have any recommendations on what brand / type of thinset to use to ensure I won’t have any problems later on?  Thanks again.
    DDay | Jan 17, 2008 07:45pm | #1
    I would just call schluter directly, just to make sure since its their product too. They'll give you the rep in your area if you ask, he might know the subfloor you are using in that area of the country and also know what thinset available is best. I used kerabond mixed with the latex over regular 3/4" ply but I don't know about advantech and similar.
    http://www.schluter.com/
  2. runnerguy | Jan 17, 2008 10:51pm | #2
    One reason for putting down another layer of plywood, whether it's 1/4" or 1/2" is typically the Avantech, Edgegold or what ever it is gets rather beat up during construction. Putting down another clean subfloor layer with screws and Liquid Nails gives a nice dirt free, paint free and drywall dust free surface for the Ditra to adhere to.
    Runnerguy
    Edited 1/17/2008 3:25 pm ET by runnerguy
  3. Litefoot | Jan 18, 2008 12:14am | #3
    gc
    You really need to go to JohnBridge.com website and use their Deflecto floor calculator to make sure that your floor can support tile. Ditra is a great product (I have used it several times) but it will not compensate for deflection in a sub-standard floor. Most tile requires a minimum 1" floor thickness.
    Mark
    http://www.johnbridge.com/vbulletin/deflecto.pl
    gdcarpenter | Jan 18, 2008 01:52am | #4
    The good news is you can use latex modified thinset between the ditra and the subfloor, so it's apt to bond quite well.
    Hope you realize that you are supposed to use NON modified thiset between the ditra and the tile.
    Let's not confuse the issue with facts!
    1. hurnik | Jan 20, 2008 11:09pm | #5
      Pardon the stupidity but what's the difference between the "modifed" and unmodified?Home Depot sells the Ditra, but I could not find a mortar OR thinset that said "modified" or unmodified.And of course, the people at HD were useless as to what to use.
        DDay | Jan 20, 2008 11:31pm | #6
        Modified has latex added. The modified takes a lot more time to fully set up, that's why they don't want you to use it with Kerdi or above the ditra. In my area, only the places that sell schluter products carry the unmodified, even the tile supply houses only stock modified. Check schluters website or call to find a dealer in your area, they will stock the unmodified.
      2. MikeHennessy | Jan 21, 2008 03:50pm | #8
        HD sells unmodified as "Custom", or some such, IIRC.
        Mike HennessyPittsburgh, PA
        1. hurnik | Jan 21, 2008 06:48pm | #9
          thanks for the info!
          1. Deleted | Jun 05, 2020 03:10pm | #11
            “[Deleted]”
  5. Piffin | Jan 21, 2008 12:16am | #7
    If this added underlayment is a wood product, i would use PL Premium running beads about 6" OC and screw it off at same layout.
    You only need to use thinset is your new underlayment is a cement based product like a hardiboard.
    normal unmodified thinset cures like concrete by a chemical process.
    Modified means latex modifiers have been added which helps bond to a lot of materials types, increases workability, resists freezing, etc, but the modified thinset dries instead of curing.
    Trapped between large tiles and the impervious membrane of Ditra, it would take forever to set up so you could walk on it or grout it.
    So read your Ditra instructions thoroughly. They do say to use what ever type of thinset is right for the underlayment type for underlay to Ditra, and to use un-modified for ditra to tile
  6. traini | Jan 22, 2008 06:05am | #10
    The un modified thin set is the package that allows a additive to be used this is usually the cheapest thin set available, modified thin will already contain a latex additive. and is usually the more expensive thin sets.
    A good rule of thumb for Schluter is when adhering to a wood product use a modified thin set ,when adhering to a concrete product or drywall use a un modified product.
    George
Wiring for Subpanels: The Right Cables
When running cable to a subpanel for a home addition, pay attention to the size of the wire and the amperage of the breaker.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
