Hey all,
I need to replace a rotten end of a beam in an old house and need to cut an in-place beam to lap joint a new piece. There is not alot of room to work and the new piece will have to be slid ito place. What is the best tool for this job?
For those still reading, I have been using a sawzall to cut all the new sill beams, but the difference now is that this beam is overhead and load bearing. I am pretty good with the sawzall, but am limited by the blades lack of stiffness so it wanders. But typically, I can clean it up before I put it in whereas I do not have that liberty with an in place beam.
I was thinking of getting a small chainsaw. I have a framing chisel and mallet, but it would take quite awhile as I have many to do.
So what is my magic tool I am looking for?
Matt
A small electric chainsaw was a major tool in my business for 25 years. We used them for framing, notching posts, cutting window openings and anything else that was rough and dirty. Years later we got a job replacing 6" X 18" glulams in a shopping center and went to an 18" bar Stihl. We typically cut out and installed 2 to 3 a day for about 6 weeks using that saw. Sounds like the perfect tool for your job. You may blow a chain or two but it'll get you in and out faster than anything else I can think of wiht less work.
They make a special chain for firemen -- can cut through asphalt shingles, nails, etc. But they're expensive and probably not available for a lightweight saw.
maybe a different blade?
Electric chainsaws are handy at times but maybe you should consider a different blade for your sawzall first.
There are a variety of stiff demo blades available, they are pricey but worth it. I've had great luck with the Milwaukee "axe" blade.
