When replying to a message……
MSLiechty | Posted in General Discussion on November 7, 2008 08:21am
How do I include a portion of the previous message so everyone can see who I’m replying too. I’ve seen some in a different color or italicized but can’t seem to figure out how to do that.
ML
  1. MikeHennessy | Nov 07, 2008 08:25pm | #1
    When you are in "Reply" mode, the original message is displayed below. Just highlight the text you wanna quote, copy (Ctru-C), and paste (Ctrl-V) it into your reply box. You can change the font size, color, etc with the property selections at the top of the reply box. Like this:
    "How do I include a portion of the previous message" . . .
    Mike Hennessy
    Pittsburgh, PA
    deadmanmike | Nov 07, 2008 08:28pm | #2
    How do I include a portion of the previous message so everyone can see who I'm replying too. I've seen some in a different color or italicized but can't seem to figure out how to do that.
    ML
    When you click on the reply button, your reply window appears with the original post below it. Just cut-n-paste whatever quote you need into your reply, then either put quotes around it or highlight it and use the button above for italics/color/size/bold/font, etc.
    Tips: when you select the quote for copying, make sure you only highlight the text and not the post#, etc.
    1. MSLiechty | Nov 07, 2008 08:37pm | #3
      How do I include a portion of the previous message so everyone can see who I'm replying too. I've seen some in a different color or italicized but can't seem to figure out how to do that.Gentleman I don't have a color/ bold/ or italics button I attached a screen shot below
      1. john7g | Nov 07, 2008 08:47pm | #4
        highlight the text and use Ctrl i for italics, Ctrl b for Bold, and Ctrl U for undrline
        hit the same sequnce to stop or undo them
        IMERC | Nov 07, 2008 10:50pm | #16
        drop to the bottom view and click on advanced view....
        go into yur profile and then open "My Prefs" and find this line item....
        Message Formatting EditorAdd special fonts, colors and links to your forum messages with controls that look just like your favorite email and word processing tools. (This feature is only available for those using Internet Explorer 5.0 or newer running on the Windows operating system.)
        check the box.....
    jonblakemore | Nov 07, 2008 08:50pm | #5
    What browser are you using?
    Jon Blakemore
    1. MSLiechty | Nov 07, 2008 08:51pm | #6
      Firefox 3.03.....
        deadmanmike | Nov 07, 2008 09:09pm | #7
        Firefox 3.03.....
        Ahh, sorry. I ####umed otherwise. I don't have any experience with Firefox. Do the function keys suggested above work?
        1. MSLiechty | Nov 07, 2008 09:20pm | #8
          Th control + keys bring up my bookmarks.....ML
          1. tenacious | Nov 07, 2008 09:26pm | #9
            You have to use HTM: coding in Firefox. If you check the box below that says "Check her if HTML tags..."<i> text</i> gives you italics<b> text </b> gives you boldingThere are other tags for color, etc., but they are cumbersome to use. Using IE for formating here, unlike just about any other bulletin board on the Net, is required for a easy user-interface.
  4. DanH | Nov 07, 2008 09:30pm | #10
    Important question: What browser (Windows Exploder, Mozilla Firefox, etc) are you using?
    Conscience is the still, small voice which tells a candidate that what he is doing is likely to lose him votes. --Anonymous
    1. MSLiechty | Nov 07, 2008 09:31pm | #11
      Firefox 3.03
      ML
      Edited 11/7/2008 1:33 pm by MSLiechty
      1. DanH | Nov 07, 2008 09:34pm | #12
        > Firefox 3.03Since Mzinga doesn't enable the special editing buttons except under Windows Explorer, you have to do it the poor-man's way. Either quote like I did above (using copy/paste) or learn how to do the fancy HTML tags.
        1. MSLiechty | Nov 07, 2008 09:41pm | #13
          >Since Mzinga doesn't enable the special editing buttons except under Windows Explorer, you have to do it the poor-man's way. Either quote like I did above (using copy/paste) or learn how to do the fancy HTML tags.Thanks Dan,ML
          1. seeyou | Nov 07, 2008 09:56pm | #14
            Or you can do as I do:
            There is an add-on for firefox that will open certain sites in IE inside of firefox. I use that for BT. All other sites open in FF only.
            https://addons.mozilla.org/en-US/firefox/search?q=ie+tab&cat=allView Image
          2. MSLiechty | Nov 07, 2008 10:07pm | #15
             Thanks Grant. Tht application is just what I needed.
            ML
