Is it better to install the interior doors before or after the dry wall.
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
After...assuming you're using pre-hung doors, it's easier to flush the jambs to the face of the drywall...
Plus, the finish materials won't get banged up by drywallers moving material around...
Ditto unless its a pocket door.
after
pre-hung wood doors ,right ?.....like residential units ..... after
knock-down steel jambs with snap-on casing ? like light commercial... before
what's the advantage as opposed to the other way around?
the steel frames go in without the doors.. and you slide the sheetrock behind the casing/jamb to lock the frameMike Smith Rhode Island : Design / Build / Repair / Restore
So it's like framing a corner with metal studs, run the drywall into the inside corner and lock it with a stud from the other wall?
yes.. the drywall locks the frameMike Smith Rhode Island : Design / Build / Repair / Restore
Knock down steel jams before the drywall? thought thats what welded jams were for and knock down were for after drywall?
maybe i've been doing it wrong?
pony
no, pony.. i think you're right, i'm wrong.. welded jambs is what i meant..
it's been about 10 years since our last one.. and i got them reversed in my thinking..
one hospital we did a lot of work for in their outpatient facilities always spec'd the welded jambs...
thanks for straightening me outMike Smith Rhode Island : Design / Build / Repair / Restore
After the drywall.....and if you can, hold off until after the floors as well.
J. D. Reynolds
Home Improvements
"DO IT RIGHT, DO IT ONCE"
