I am finishing off a cabin that I have subcontracted much of the work on. The cabin is a chalet style with vaulted ceilings (roof pitch is 12 in to 1 ft, I believe). There is a large glu-lam beam that goes the length of the cabin. The drywall is butted (gap of 1/4″ to 3/8″ of an inch anyway…) up to the top of the glu-lam. I am looking for a method of finishing this area off. Should I just put a thick bead of caulk up between the beam and the drywall? I was reading the label of a tube of DAP caulk which suggested that a piece/strip of foam be inserted in the gap prior to caulking (if the gap is greater than 3/8 of an inch or so). Any ideas or suggestions? Also…..any ideas on how to finish the exposed glu-lam beam? It looks pretty good as it is with the exception of a few patching compound marks. I am thinking that it needs some sort of protection….maybe a light sanding and three coats of a wipe on poly??? Thanks for any suggestions….
Adam, click on the link below for an archived thread that deal with your question.
So you subbed out the work and that was the best they could do?
< Obsolete Link > Drywall
