HO has a triple toggle switch in a single-gang box (ca 1950) that is going bad – sometimes won’t turn off or it trips internally with an audible click after as much as a two-second delay.
HO’s switch has three hot terminals and it is wired to two different circuits – Switches A&B jumpered together, switch C on a different circuit. Problem is, the only triple switches I can find now have a single hot terminal for three load terminals – I’ve looked at HD, Lowes, Ace Hardware, even Hank’s Electric supply that caters to electricians.
Leviton’s pathetic website shows only one commercial grade triple and none in residential grade.
Before I tear into their lath and plaster wall to install a double-gang box with a double and a single switch, does anybody know where I can get a triple with three hot leads?
Thanks,
I see what you mean about the Leviton site. I remember seeing a bathroom vent/light/heat switch by nutone IIRC. Can't remember how it wired up, seems like it had sep line terminals. You still may need to go to two gang box or go real deep for wire fill though.
http://www.nutone.com/product-detail.asp?ProductID=11209
Thanks, but the Nutone switch is exactly same as Leviton - probably re-branded.
BruceT
Check Broan and Pasasonic and other fan companies.I suspect that some of them with heaters are setup for a 2nd circuit. The heater might draw enough current that it takes a separate circuit. But I have not looked at it to see..
Thanks, I'll check out Panasonic. I think Broan is the same company as Nutone now, but it may be worth a shot.BruceT
Hubbell HomeSelect has them too
here is the Hubbell I mentioned....
http://www.hubbellcatalog.com/HomeSelect/datasheet.asp?PN=RCD111ALjust have to pick the color you want.
Based on the picture is look like it has one common terminal.That is the hangup.But he has loads on 2 different circuits. Unless he can rewire it he needs ones with separate terminals..
he could check the amperage and cap one feed off .... or replace the box with a two gang.
Thanks, but Hubbel has the same problem as Leviton; only one line terminal.
BruceT
What you might be looking for is called a Despard switch assembly. You buy the switches and bracket separately and assemble them to fit in the single-gang box. See the link below...
http://www.kyledesigns.com/product/ACD1-I_DESPARDSWITCH
Ace Hardware as well as others should have them in stock.
Edited 2/19/2008 10:11 am by allaround
Thanks. Despard might work, but HO wants white like the old one and Despard comes only in ivory with a steel cover plate.BruceT
Bruce,
Looks like Despard devices come in ivory, white and brown.
http://www.passandseymour.com/pdf/T11.pdf
Here's a link to the matching wallplates.
http://www.passandseymour.com/pdf/S17.pdf
"Looks like Despard devices come in ivory, white and brown."Well now, that looks like a possibility. I thought Despard was a manufacturer, not a style.Further looking on Pass & Seymour site turns up a decora triple switch with two line terminals
http://www.passandseymour.com/pdf/A17.pdfSo it looks like you have turned me onto two possible solutions.Thanks.
BruceT
another link to P&Shttp://www.passandseymour.com/.
http://www.energyfederation.org/consumer/default.php/cPath/39_766_765
Thanks, but I've already determined that Leviton has only one line terminal and I have to replace one that has three line terminals (two would work as well).
BruceT
Bruce
Are the two circuits any where to the max load? If not and the nuetrals are in the sw box can you cap off line c and put it on the same circuit as A&B or the reverse doing the same with the nuertals of course if you can not find the switch you are looking for?
Wallyo
"Are the two circuits any where to the max load? If not and the nuetrals are in the sw box can you cap off line c and put it on the same circuit as A&B or the reverse doing the same with the nuertals of course if you can not find the switch you are looking for?"I have not investigated that yet; seemed easier to find a replacement triple switch. My first impression is that if the combined load were within limits for one circuit, the original sparky would have wired it so in the first place.It still baffles me that dual switches are made with two line terminals and a breakable tab so you can wire them on separate circuits, but triple switches have only one line terminal. Both Leviton and Cooper are that way.
BruceT
Look again. My dad found one at either Lowes or Depot for a job we did a few years ago. It was a decora style.
"Look again..."I looked - at HD, Lowes, Ace Hardware, local professional electric supply house, Leviton website, Cooper website, Nutone; not available and no one could offer me a clue.BruceT
