Just got my latest issue of FHB. Wow wouldnt you know it an article on installing vinyl windows. Wait what was last weeks JLC (journal of light construction) article, installing vinyl windows. Ok one was vinyl clad. Still it suprises me how similiar the topics are. Water proofing foundations, testing the same power tools, laying out and framing walls. Let me guess, next month JLC will do I-Joists and curved stair railings and FHB will do leak proof metal roofs and building on problem soils.
Are you guys in the same office building or the same country club ?
It doesnt really matter, I get good tips from both yet prefer FHB.
Fine Homebuilding Recommended Products
Speed Square
When it comes to framing, it doesn’t get much more fundamental than a speed square — and with its sturdy metal build, Swanson’s will not let you down. Some of our team members have had theirs for 20 years.
Utility Knife
This utility knife is well-made and comes in handy when cutting rigid foam insulation. You can extend the snap blade to cut through a 2-inch foam board.
Code Check 10th Edition: An Illustrated Guide to Building a Safe House
It would be great if this book didn’t need to exist, but it's definitely a must-have. It's a one-size-fits-all code book that's easy to understand and will help you sail through your inspections.
Nitrile Work Gloves
Do yourself a favor and protect your hands while you work. These lightweight, breathable work gloves will keep your hands safe while cutting and fitting.
Handy Heat Gun
This heat gun is great for drying joint compound, primer and paint when patching drywall and plaster walls. Plus it can soften adhesive, get a very cold small engine to start, and shrink heat-shrink tubing.
