Why is my breaker tripping?
jmac | Posted in General Discussion on April 18, 2006 04:31am
I have a 1921 bungalow. Wiring is generally updated, but some artifacts from a while ago exist.
My bathroom had a single fixture light at the end of a circuit. The power source fed in from another room with a box with multiple wires in it. The power came into the bathroom to a box with a single-pole switch. From the switch the power ran to the overhead light. Black to switch, black from switch to light, whites joined.
Here’s the question: Why does the breaker trip if I join the source feed wires in the switch box. (i.e. I connect the black and white wires from the source where they used to control the switch and overhead light)? It does not trip if I cap each wire individually.
This is probably a dumb question but I figured why not ask. Thanks in advance.
By the way: I tested the source: 120 volts, and it doesn’t trip when I use the multi-meter.
    MarkH | Apr 18, 2006 04:44pm | #1
    Because that shorts hot and neutral together.
  2. junkhound | Apr 18, 2006 04:58pm | #2
    Mark is correct,
    your breaker better trip pretty fast if you tie the black and white wires together - in a typical house, you likely are getting 200 to even upwards of 1000 amps short circuit current flowing.
    No question is a dumb question, but it does indicate that you need to go to the library and learn a little more before randomly tying wires together!
    I'm 100% for DIY anything, with a knowledge base; however, you have a high probability of doing something that could harm your family if you don't find out a little more about electricity and home wiring.
    1. jmac | Apr 18, 2006 05:40pm | #3
      thanks. i've already called in someone to help out (licesned electrical guy). I figure you all could answer this quickly though.Follow up dumb question: why does having a light there not make it trip-- doesn't the hot flow though the light and back thorugh the neutal? why does having something in between solve this issue?Promise, this is the last dumb newbie Q. (for today)
        Soultrain | Apr 18, 2006 06:04pm | #4
        The light fixture has resistance which reduces the current flow.  A 60 Watt bulb only draws 0.5A (60W / 120V = 0.5A).
        1. jmac | Apr 18, 2006 06:12pm | #5
          thanks.
A Practical Perfect Wall
  • The New Old Colonial
