Need some help with my 100 year old windows. I am removing them to reglaze and paint and was wondering which is the best way to remove the old windows along with the track that they run up and down with? The aluminum is able to be wire brushed but can bend easily so is this the only method to use when cleaning them up? Also after cleaming do I use some silicone or something to coat them so they do not corrode?
There is a small strip holding the double hung window in and I’m afraid I may break it when removing the upper window but can anyone tell me if there is a preferred method of removing the window?
As you can tell I’m attempting this for the first time so thanks ahead of time for putting up with some stupid questions.
If the house is in fact 100 years old, then the aluminum is a later addition.
You should start by removing the interior stops. In general, if theres been aluminum spring-strips added, you'll need to remove both the upper and lower sash at the same time along with the aluminum.
Use a stiff knife like a 5in1 to get the aluminum strip loose from the wood. Then tilt the whoe assembly out.
If there is still a wood strip between the lower and upper sash, then the above is done in two processes. First, do the lower sash from the above instructions. Then use pliers and a pry to remove the parting strip. Then continue with the 5in1 and removal.
Then go get a really good book that deals with rope-hung windows. Rehabilitate them, and throw the aluminum away. You'll love yorself for it. Really.
Support our Troops. Bring them home. Now. And pray that at least some of the buildings in the green zone have flat roofs, with a stairway.
If you do have the wood strip between the upper and lower sash (called the parting stop) the easiest way to remove it is to completely lower the upper sash and remove the parting stop from the top down.
