Windows, windows, windows – What to do??
trygrr | Posted in General Discussion on October 9, 2007 01:47am
“Long time lurker, first time poster!”… bonus points to the member who names the movie that that line is, sort of, ripped off from
I’m looking at 2 quotes from 2 different suppliers that are within peanuts of each other, but I can’t decide which to buy. What do you guys think??? Don’t worry, much detail to follow.
Aluminum clad, clear pine interior, double hung, 6 over 1, simulated divided lite windows. Big windows. Some of which are taller than I am. Yes, each rep quoted screens and 2×6 walls. The sizes are almost exactly the same and they both put in tempered glass where required. So what to do. Here it is:
Lincoln vs. Peachtree
Tell me what you think.
And thanks,
  1. Piffin | Oct 09, 2007 03:18am | #1
    So which in your area has the best reputation for after the sale service?
    I don't know Lincoln, but what I've heard of Peachtree going downhill over the years on service would keep me facing the other way.
    I used to like Peachtree but that was twenty years or more ago.
    EricPaulson | Oct 09, 2007 03:19am | #2
    A Bud of mine did Lincoln clad exterior green.
    Looked like nice windows. Pine interior/tilt wash............
    Hope that helped.
    [email protected]
  3. Piffin | Oct 09, 2007 03:21am | #3
    BTW, Tiger, I didn't know they did a movie about Breaktime! LOL
    BillHartmann | Oct 09, 2007 04:06am | #4
    Might want to compare the specs.
    Some 3rd party has all of the spection on windows. Think that it Fenstration REsearch Council or something like that.
    1. RedfordHenry | Oct 09, 2007 06:26am | #7
      It's the National Fenestration Rating Council (http://www.nfrc.org).  Actually, I don't think they do a lot of independent testing, maybe some, but I think they just publish the data provided by the manufacturers though I could be wrong.
      As for the choice between the two window manufactures, I'd also consider U values and infiltration factors (info should be available at the above website if they are members of NFRC.
    shelternerd | Oct 09, 2007 04:22am | #5
    My understanding is that Lincoln is a better window than Peachtree but that they have un-conventional sizes so their rough openings are non-standard. Did you check the RO's to confirm that the quotes are identical?
    I used Peachtree on our last house and the experience was flawless. We got the top of the line with the Zoe glass that has the self cleaning coating and had the factory install crew set them in the openings. Every thing went perfect.
  6. sledgehammer | Oct 09, 2007 06:05am | #6
    I spent 90 minutes on hold with peachtree trying to get a page faxed to me on how to replace the rotted center on a 10 year old door. The leak also destroyed about 4 sq/ft of plywood subfloor and 2 joists.
    Hope this helps.
Fast, Accurate Wall Framing
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
  • Insulation Scrap Dispenser
