In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Wiring 220V recepticle for tools
| Posted in General Discussion on November 30, 2002 04:06am
I have several power tools that use 220 V and they have 3 bladed dryer plugs on them – two angled blades and one that is a L shaped.
Just bought another house and it’s time to wire in a plug.  The handyman strung the wire –  10-3 w/g, but I’m confused as to how to wire the plug.  Red and black to the two angled blades, but what to the L shaped blade?  Any what to do with the ground wire?  The tools use only 220V, and do not use 120V like a dryer.
There are only 3 inputs to the tools: 220, 220 and ground.
    BillHartmann | Nov 30, 2002 05:51am | #1
    That is really the wrong recptacle.
    Here is a chart showing the different standard series of plugs and recptacles.
    You have 10 series (10-xx where xx is for the different current ratings).
    It is an ungrounded 120/240 socket. In the past they where allowed for use with driers and ranges. But since 1996 (and older in some circumstances) new installations need to use a socket with which also inlcude the ground. For 120/240 circuits that is the 14 series.
    For a 240 with ground you want the 6 series which is what you should have used in the first place. The ground connects to the round pin and the white is not used.
    1. 4Lorn1 | Nov 30, 2002 06:21am | #2
      Red to one screw. Black to the other. The 'L' shaped blade get the bare or green ground wire. The white gets capped off in the box as it is not needed. It would go to a neutral connection had the tools or receptacle needed or used one as it would to run something on 120v.
      Work it dead. After getting everything together check the voltages and for the presence of a ground at the receptacles. If everything seems OK plug in the tool and cautiously try it out. If it runs more slowly or lacks power recheck everything.
    2. cbeals | Nov 30, 2002 03:38pm | #3
      Bill
      Thanks for your response.  Couldn't view the chart you mentioned.  Is there a link to it you could send?
      [email protected]
        BillHartmann | Nov 30, 2002 04:27pm | #4
        I guess I forgot to post the link.
        http://www.networkcable.com/pages/components/nema_nonlocking.html
        Here is another one organized in a different way.
        http://www.quail.com/locator/nema.htm
        Edited 11/30/2002 8:29:31 AM ET by Bill Hartmann
Hassle-Free Window Screen
This retractable screen from Pella maximizes convenience and function.
  • Designer Kitchen Cabinets on a Budget
  • Podcast 459: Leaky Attic Stairs, Right-Sizing Heat Pumps, and Vapor Barriers in Dirt Crawlspaces
  • Linda Reeder: Architect, Professor, and Author
  • Podcast 458: PRO TALK With Glue Expert Bob Behnke
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Tool Guide 2022
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
