I need to install a prefinished T&G Bamboo floor on a pre-existing, well curded, concrete slab which is in good shape. This will be in a remodeled entryway connecting to several rooms which have tile floors. I would like to avoid installing any sort of sleepers or subfloor so as not to create a finished floor height out of wack with the rooms that the entry serves.
I am contempating applying an epoxy sealer to the slab and gluing down the flooring but am worried about the long term viability of this installation method. Any Suggestions?
Adam
I'm here in TX and everything is a slab! I've been told that as long as the flooring is the 2 1/4" stuff you can glue it down to concrete.
Others with more first hand knowledge on the subject will be along to add to this.
