Wood floor over staple-up radiant floor
azreich | Posted in Construction Techniques on November 20, 2003 07:05am
I will be putting in a 3/4″ wood floor over 3/4″ OSB with a radiant floor heating system stapled below the OSB. I believe the temperature will be 148 degrees or less. Do you any knowledge about the type of wood floor I should use? I’ve heard that as long as I turn the heat on for several weeks until the OSB is dry and bring in the wood for a few weeks before I lay it, I can put down any floor I want. I’ve also heard that I should use only quartersawn oak or American black cherry in 2-1/4″ widths. Any thoughts are appreciated.
  1. davidmeiland | Nov 21, 2003 07:59pm | #1
    I've put 2-1/4 rift white oak over radiant floor with no problems. Get a moisture meter and make sure that the subfloor and hardwood flooring are at approximately the same moisture content. It's helpful to unbundle the flooring and distribute it around the room (as opposed to leaving all of it bundled and stacked in one corner). Lay the flooring, rough-sand it, and apply filler. Let it sit a couple of weeks and then apply more filler, sand it, and finish it. It's a pain in the #### to schedule this way but it's worked well for me.
    Staple-up under 1-1/2" of material will be somewhat slow. Our house with the radiant had areas of 5/16 flooring and areas of 3/4, and I could tell the difference. Make sure it's correctly insulated underneath.  I think that a layer of bubble-foil insulation under the tubing and above the fiberglass is a good idea.
  2. blackcloud | Nov 21, 2003 10:17pm | #2
    Allen,
    Like the previous post it is important to let your wood acclimate.  There are several species of wood that are better then others, Brazilian cherry is wonderful (very stable)  talk to your local floor guy, local radiant guys and get what worked for them.  Also do a search of this site there have been numerous discussions on this topic.  I used 3/4"  2 1/2" wide hickory/pecan prefinished and installed myself.  Also using a prefinish has the advantage of not showing gaps as much, do to the micro bevel of the boards.
    Jason
    If it wasn't for bad luck I wouldn't have Any!
    1. azreich | Nov 21, 2003 10:52pm | #3
      Jason,
      Thanks for the info. Some say you can only use a few types of wood. I'm now hearing that you can use most popular types which is good news. Regards, Allen
The Fine Homebuilding Interview: Katrin Klingenberg
This architect and engineer developed a Passive House standard for the United States. In this interview, she discusses what it will take to move the building industry toward climate-positive realities.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
