Wood Flooring over OSB?
| Posted in General Discussion on December 20, 2004 02:31am
I have a customer who would like hardwood floor installed in his new home. The builder installed OSB in the areas where the hardwood floor is to be installed; after being told to install plywood. Will this cause any problems such as a squeaky floor or other problems?
  1. woodguy99 | Dec 20, 2004 05:05am | #1
    If it's Advantech, it's no problem at all.  If it's another type of osb, still shouldn't be a problem, but might help to run flooring perpendicular to joists.
    1. Schelling | Dec 20, 2004 06:43am | #2
      I agree. I know that you are not supposed to put wood flooring over particle board but have not heard the same about osb and definitely not advantech.
      1. DArgus | Dec 21, 2004 04:14am | #3
        Thank you for the reply. I will check to see if it's Adavantech. I am planning on laying the hardwood floor at a diagonal with a border.
        1. Piffin | Dec 21, 2004 10:15pm | #4
          Diagonal doesn't count the same as perpendicular. Thickness of the subfloor makes a difference too. It should be at least 3/4" over 16"oc
