Hi all!
I am in the middle of my first try at installing wood flooring (3/4 inch think, 2 1/4 inch wide prefinished ash strip flooring), and have some questions about tongues that are partially missing. Should I avoid using boards that don’t have a full width tongue?
Out of 12 boxes (20 sq ft each), I now have at least one box worth of boards with partially missing tongues. When I say “partially missing” I mean they are not the normal width, sometimes as small as about 3/32. Typically, the tongue on these “defective” boards taper from full size to something less than full size, but I do have some boards that don’t have a full width tongue the full length of the board. Unfortunately, the problem tends to be on the longest boards.
Is it normal to have this many boards (about 8%) with short tongues, and can they be used (for example, if scattered about in the floor)? I ordered 10% extra (to account for inexperience, knots in this natural grade flooring, and defects), but most of that extra is being taken up in these short tongued boards and I am afraid I won’t have enough to finish. But I don’t want to harm the integrity of the floor by using these boards if that would be the result.
FYI in case it helps answer the questions: this is in a home built in 1978; subfloor is 1/2 inch ply over 3/4 inch ply on standard floor joists on the main level over a finished basement; flooring installed perpendicular to the joists; using a Porta-nail Hammerhead2 pneumatic nailer; flooring is at 8% moisture level; house typically kept at 40-60% relative humidity level throughout the year.
Thanks for any help or suggestions you can give.
Nat
Fairfax, Virginia
typically, i decide on a piece by piece basis..
you don't need the entire tongue to hold the two adjacent pieces in alignment with each other..
if, besides having a partially defective tongue, it also has a bad grain, or a surface defect.. then i put it on the cull pile..
save your cull pile for possible use in other situations.. like rips
