Wood Railings/Concrete Porch
| Posted in General Discussion on September 14, 1999 03:30am
I’m installing a pressure treated wood railing on a concrete porch and was wondering what the best way to attach the notched 4×4 to the concrete slab. They would set on the edge and I would drill into the side but am not sure of what size bolts or if there are anchors of some sort that would help create a nice sturdy railing. The iron ones wobble too much
Brian
  1. Brian_Hess | Sep 14, 1999 03:30pm | #1
    I'm installing a pressure treated wood railing on a concrete porch and was wondering what the best way to attach the notched 4x4 to the concrete slab. They would set on the edge and I would drill into the side but am not sure of what size bolts or if there are anchors of some sort that would help create a nice sturdy railing. The iron ones wobble too much
    Brian
  2. Guest_ | Sep 14, 1999 03:30pm | #2
    Brian,
    If they set on the edge there are several premaid anchors available. I would have to see your set up to tell you which one to use. A good lumberyard or hardware store may be able to help. A home center may help if you can find someone who knows what they are talking about (good luck)!
    Set the anchors in with epoxy.
    Rick Tuk
