hi everybody. does titebond regular yellow woodglue work in really cold weather or even below 32 degrees. does the glue even bond or dry. i am glueing flat panelmouldings onto pieces of plywood.
Not well enough to trust to stay glued is my exp.
The new TBIII can stay useable for 10 freeze thaw cycles IIRC, but glueing below freezeing is just not a good idea. Even PL Premium liquid poly suggests 40 or higher.
it may say on the bottle
"I'd rather be a hammer than a nail"
Do not freeze it. IIRC, TB III requires 47 degrees and I and I may require 50 degrees.
It's a water-based glue. It will freeze in the bottle. After it cures it will withstand ssome freezing.
In my exoerience, assembling wall frames ( faux wanscotting) in a cold garage, Titebond II will not work much below 40 degrees, it sort of forms chalk instead of bonding. Titebond III supposedly works a few degrees colder. I just moved out of the clients garage for the assembly and jsut did the cutting out there
