I have just realized that the wrong grout was used on my bathroom wall tile. Sanded grout was used on 4″ tile. Does the grout need to be removed and un-sanded grout used or can the sanded grout be left in place until it fails. Will it fail sooner because it is sanded??
From plumbing failures to environmental near disasters, OHJ staffers dish on our worst and best moments.
Steve,
Joseph Fusco
"The price of apathy towards public affairs is to be ruled by evil men." -- Plato
The tile was standard 4" wall tile with approx. 1/16" to 1/8" spacing, the grout seemed to go into the spaces fine but I wonder about the adhesion.
I have just realized that the wrong grout was used on my bathroom wall tile. Sanded grout was used on 4" tile. Does the grout need to be removed and un-sanded grout used or can the sanded grout be left in place until it fails. Will it fail sooner because it is sanded??
I typically use sanded grout in walls with grout joints 1/8" and larger, and am sure it will not scatch the tile. The sand will give you a stronger joint. So, unless it scratched your tile, or was installed improperly, it should be fine. It must have been pretty hard to get the grout in a 1/16" joint. Try lightly scratching one of these "thin" joints in an obscure area if possible, to see if the joint was filled or the grout is just on the surface.
